I just picked up a 6 pill Fatboy amp fo a unbelivable price. I know I need to drive it with something but I'm not sure of whats the best driver for it. Any info would be great. Thanks
300 watts to drive six 2879's ?
75 to 80 watts deadkey into 6 transistors that only need 7 to 10 watts each for max clean output ?
You don't have a clue about competition amps.
15 watts key into a 6 pill will give you 250 out.........250 watts peak will give you 1200 watts out.
For someone who has not owned anything but an ancient garage sale 2 pill amp you sure think you're some kind of an expert.
I remember the comment you made about the proper driver for a HD 8 pill......you said it was a 1 pill.
You still haven't learned that comp amps and stock amps have 2 different purposes so until you educate yourself......knock off the bad advice.
