Version UP history
The past contents of Version UP are as follows.
* Version 1.1 (2010-Jun)
(1)Enabled to indicate the model name "VX-8G" when receiving a position packet from a Yaesu "VX-8G" transceiver.
(2)Corrected a problem where under certain circumstances the transceiver would lock up when receiving a "NAVITRA PACKET".
(3)Corrected a problem when an APRS message is being read using the FVS-2. If you transmit during this time the transmitted audio would be muted until the FVS-2 completed reading the message.
(4)Corrected the model name displayed when a position packet was received from a Kenwood "TH-D7" transceiver.
(5)Corrected a compass error in the south latitude/west longitude directions when using the Heading UP display.
(6)Corrected a state of the compass display mode of an APRS position packet may not be held.
(7)Corrected a fault where if SET MENU G03 is set to (AUTO STEP) and if the SQL type is changed the VFO step rate would default to 5 kHz steps.
(8)Changed a control so that the SQL port output signal of a Data jack might be interlocked with a TSQ/DCS signal.
* Version 1.0 (2009-Dec)
Initial Version
