Ebay sure is entertaining!
psycho
Running a special on our rooms!
Aug 25, 2006
3,433
1,318
173
Floriduh
Didnt you know for a "CB" amp.... that you are suppose to pay $1.00 a watt
If you go by Bird watts.....the 250 might be worth $80.....Dosy watts maybe $125. Apparently the aging process makes it more valuable, since it was an amp built in the early to mid 1980s. Only $228.05 shipped to the "buyer"....for less than that you can buy an X Force TNT 250 brand new shipped to your house.
This amp will be up for auction again in 6 months.
Thank goodness the dollar a Dosy watt theory doesn't apply to 8 pill comp amps!
If you don't know why this amp is worth $200+ then you must not have read the description:
<proof> 'i know a lot of power comes out of these units only because , sometimes he would put a floecent tube up to the truck antenna and key up , and it would light up !!!'
An amp that powerful must be well worth the money... :rolleyes:
:laugh: That kind of power should only be used by those who can use it safely!
    63Sprint has left the room.
