iPortable iP60z Field SWR Antenna Analyzer
Happy_Hamer
Administrator
Staff member
Mar 22, 2001
5,058
201
123
Like many others, I have been using the MFJ 259B Antenna Analyzer in the field.
I was watching an instructional video on the Buddipole website and seen the iPortable Analyzer.
So I purchased mine from Buddipole so I can also purchase some extra clips for my antenna at the same time. Same price at iPortable
Here is a photo just for the size comparison
I will make another in focus, but you can get a feel for the size
A bit less in cost than the MFJ-259B.
Did you ever try the Autek RF-1 analyst?
I have a friend who has the Autek and I was not as impressed with it as much, maybe because this is just so simple like me is why I like the iPortable LOL :D
I wanted to play with the analyzer so I set up my Buddipole as a VersaTee Vertical.
Once set up, including the elevated radial wire,, I just "drug" the lead up and down the coil and watched the SWR and impedance on the iP60z until it was as close as I could be to resonance. I was also using my 6 section adjustable shock cord. So I fine tuned it with the adjustable bottom section.
Now I know it is similar to just hooking up to the radio and dragging the lead for maximum noise level. After comparing the tap location with the noise level method and the iP60z I discovered it is just a coil ring or two difference.
I have the internal tuner on my KX3 so it would tune either method with no problem. Like I mentioned before, this tuner will tune a dog's tail LOL. In my mind though, if the antenna is adjusted to the best efficiency possible, then use the tuner, you would be getting the max radiated power? Correct? Every little bit is important when operating QRP. That is why I prefer set up using an analyzer. YMMV
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
