Tuner SWR same on Inductor A-F??
CB590
W9WDX Member
Jun 29, 2016
1,539
1,255
173
Trenton Nj
www.590dx.com
My MFJ-941e tuner works great to tune all bands with SWR of 1-1 or 1-0 on most all bands. Using the normal (to me) K,L,E,J inductor and various cap settings.
But on 24.990 I get a 1.2:1 no matter if the inductor is set on A-F it doesn't matter.. This is with Transmitter and Antenna caps set at 1/2 and 1/2..
So 1/2-A-1/2 would be setting.
I get good reports on all the other bands from various states. I haven't heard anyone on 12m yet up this way (PA).
Is this possibly normal??? Should I still leave it set on A or set it to F??
ALWAYS use the MINIMUM inductor setting possible regardless of band...even if VSWR is like 1.5 or even slightly higher...
This is the most efficient tuning(most power to antenna) and least loss thru tuner...
Remember even at 2:1 Vswr your radiating 95% plus power to antenna
All the Best
Gary/W9FNB
All the Best
Gary/W9FNB
So use F and not A inductance. Since A is Max and L is Min. ?
OK. Here's the inductors on different bands.
W/1:1 MFJ inline choke on coax approx 8' from xmitter just outside shack wall:
3.8 E
7.2 H
14.28 J
18.1 J
21.3 K
24.94 A
28.40 K
Without 1:1 on coax
3.8 F
7.2 I
14.28 H
18.1 J
21.3 K
24.94 H
28.4 K
The only noticeable worse is on 14 MHz where it went to J with choke. And at 24.94 from H without choke to A (of F).
Opinions??
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
