Tube Radios
Raccoon
Well-Known Member
Oct 27, 2005
217
108
53
56
www.youtube.com
I love vintage radios , especially the old tube type radios . So I was wondering , are the tube type radios worth messing with to use as a daily driver ?
And if so , what classic tube radio is the best CB for the money right now ?
I know it's not always easy , but it is possible to find a 40 channel tube radio , that has USB & LSB in it ... or at least the possibility of having 40 channels .
I also like the old solid state equipment too ... but I've been leaning towards purchasing a tube radio , so I figured I'd post this question here , and see what everyone's opinion is on the subject .
The Browning Mark 2's or Mark 3's seem to be the most coveted. I believe the Mark 4 is the SSB model.
These are nice and are commanding a pretty penny for them in good condition.
These are 2 piece units meaning 1 box is the transmitter and the other is the receiver.
I'm sure you heard the modern term "trans-ceiver". Now you can see why modern radios are called that.
Reactions: Raccoon
The Mark III offered two transmitters. One was AM only. The other was AM/SSB. It's the same size as the receiver. Made a real impressive setup. I had one many moons ago.
Reactions: Raccoon
Best AM only radio I ever had was a tube radio. The Pearce Simpson Guardian 23. Didn't look like much but boy was it a loud talker.
Reactions: Raccoon
Not exactly the same and not 11 meters but this is my daily driver. It does have the coveted FM board installed. While it is a hybrid it does use 6146b finals. For pure 11 meter I always wanted a Tram D201.
I use a Cobra Cam 88. Tube radios have ultra clear receive & transmit audio. I have a Cobra 87 GTL back up. The Cam 88 has modified modulation.DSCF3429.JPG
Yep, speaker. The Cobra was bought used in very good condition. I recently bought the Cobra 87 GTL as NOS. The 87 GTL is dual conversion receiver with a ceramic IF filter in each conversion. Like a Cobra 2000. It also produces monster audio with one diode clipped out of circuit. Same chassis Cobra 89 GTL. I prefer the flat square face vs slanted face on the 89 GTL.
I see no load and plate control knobs, do I assume that's an early solid state transistorized radio?
CB radios do not have plate & load controls on the front panel. The controls are on rear and only need possible adjustment with an RF tube change. A screwdriver & possibly slug alignment tool is used.
Reactions: Captain Kilowatt
    63Sprint has left the room.
