signaLink
ahasverus
Dec 2, 2011
68
3
18
dear Knights in the Ham
i bought the cable sl6pm cable(tigertronics)
when i use the 8 round pin cable /the input mic tx/ the signaLink /audio from pc /there is
no problem
when is use the 6 pin cable (sl6pm)/ input data (rear tx ft1200dx) no audio to transceiver from pc
(led on signaLink is on when sending audio from pc)
my question
i use the prewired jumper yaesu 8 pin in the signaLink
is it possible i need another jumper ?
or is it possible i had to change some settings in the software transceiver?
is the audio v sufficient from signalink to transceiver ?
i try to avoid each time changing the cable signaLink and the cable mic
(audio from pc /audio from mic)
i should be much obliged
on3bm
no problem
my question
on3bm
no problem
my question
on3bm
solution to have the input mic/tx free and send audio from pc to the TX
signaLink
connect the pins in the jumper in the right way
(see tigertronix signaLink)
connect cable data tx to signaLink
power signaLink via usb pc
for ft1200 dx
cable 6pin SL6PM
jumper sl mod6pm or connect by wire
    63Sprint has left the room.
