The thought is ok, but woukd entail some major redesign, as well as major new design. In the FET mods that I've done (cobra 29's primarily), I see carrier levels of around 5 to 6 watts, with my Wavenode system regularly recording 40 to 45 watt peaks. I've had customers come back after having the EFT mod done and tell me they walked on guys running amps. The only things I do differently from the cbtricks procedure is use higher cap values, change the driver base input resistor to 4.7 or 3.9 ohms, and add a 33pf cap to the spot where the 1k resistor is removed (i forget the number right now, its near the antenna socket by the SWR bridge circuit). Oh, I usually replace that 1k with about 15k so there's still bleed-off for any static electricity that might be building up.
