Stryker 955hp bias test point?
I think the measure point is at the power cord.
I measured it at the fuse and measured it at the lowest the VR would go, say 460ma then upped it to 560ma, followed the list and now I dont hear the "crunchy" background noise.
RX is now the required 400ma
bias set.(y)
Reactions: BBB
Look . . . if you cannot test the bias setting properly; then don't bother to do it at all. You don't want to ruin your radio. I'm sure that it has MOSFETs, so you might consider sending to to the Stryker repair station if your radio is acting like it is out of whack - as I'm sure that it is probably still under factory warranty.
Reactions: rabbiporkchop
Yes, the Stryker SR-955 has MOSFETS for the finals. Some have FQP13N10 finals, and I do believe the most recent radios have IRF520 finals.
The Schematic diagram for the radio indicates the measurement points for the bias settings. The Alignment procedure documentation instructs the correct procedure. And the procedure instructs the bias setting in milliamps, but also instructs that all four final MOSFETS to be checked for same voltage.
The data sheets for both of these MOSFETS show the ON characteristics for the GATE voltage to be a minimum of 2.0 volts, and a maximum of 4.0 volts.
There is one back-door method.
Start with all the trimpots set to zero gate voltage.
Put a digital current meter in line with the radio's positive power wire.
Set mike gain to zero, select either USB or LSB and key the mike.
You will see a steady current draw. Advance the first trimpot until the reading climbs by 20 mA (0.020 Amp). Repeat this for each one.
You may desire more than 20 mA of idle current per MOSFET, but you should get the idea. Advancing each trimpot so that it raises the current reading by the amount each transistor should draw with no drive power.
Reactions: 357
thats exactly what I did.
bias set.(y)
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
