148gtl made in china my rx/tx light is not working as well as transmit and recieve, any help would be great .what works is my channel display and meter lights also very fanted noise on speaker also hear that clicking noise when i keyup.
yes the inner wire has 8volts in all modescheck what Robb left you and see if you have 8 volts in and out of the band switch. should have 8 volts into the switch and then 8 volts out to aM, SSB modes. this is the switch for AM, LSB and USB. the in wire will have 8 volts constantly and as you turn to each other leg the voltage will move from AM, LSB and then USB.
