2340 CLIPPER/LIMITER BOARD MOD
Discussion in 'General CB Services Discussion' started by Sonar, Aug 26, 2017.
  1. Sonar
    Sonar
    Expand Collapse
    Apr 8, 2016
    886
    316
    I've two FS 2340's. .
    One has the audio clipper/limiter board totally removed, and the other has the board intact, but bypassed.
    I saw this one on eBay (it lasted about a day.)
    Can anyone tell me what this device added to the audio limiter board might be.
    I've had other 2340's, and saw some mods done to boards which went beyond bypassing them, but never this. I notice (in the photos) what appears to be a resistor that's not attached.
    Can this cause the rig to have audio issues? Thanks. 73
    #1 Sonar, Aug 26, 2017
  2. Onelasttime
    Onelasttime
    Expand Collapse
    Aug 3, 2011
    445
    164
    Why not rebuild the circuit and put it back inline and see. Clipper Limiter's if that is what this is limit audio bandwidth to increase average talk power. SOME KNUCKLE DRAGERs like hifi overly broad audio. Problem is you become a splatter box and make less efficient use of your power. I have never worked on one of these but have been told that in stock trim they have nice loud audio.
  3. nomadradio
    nomadradio
    Expand Collapse
    Analog Retentive
    Apr 3, 2005
    1,183
    661
    The Sonar's audio power was just barely sufficient to modulate the final. The clipper circuit board was meant to hold the audio to a level that wouldn't overdrive the modulator tube.
    The "I want more" crowd will bypass it every time.
    Sonar likes this.
  4. Sonar
    Sonar
    Expand Collapse
    Apr 8, 2016
    886
    316
    I do believe bypassing the limiter creates splatter, but in all honesty I've never received a single complaint.
    Unfortunately there's only one way to use an amplified mic or in my case the Demco modulator with this rig, and that's to bypass the limiter.
    I use my Demco modulator spearingly (@ 10 o'clock) and not only get excellent audio reports, and no reports of splatter. I understand that doesn't mean it's noy happening.
    I do believe in not bypassing limiters and or turning up the audio pot but until one hears how these tube rigs sound with the Demco (especially the 2340) as opposed to a non amplifed hi Z (which is all that can be used without the mod) without the modulator I guess you don't know the difference it makes.
    I don't know how much extra punch/audio stays on the frequency I'm transmitting on but it's substantial. These Sonar's only have two small 6bq5's (push pull) as opposed to the single large audio tube that's in say a tram d201/a. I'm fairly positive some of that audio is lost, but some must be staying on the operating frequency. I've heard the FS 2340 stock (unmodified) with an unamplified d104 then the limiter bypassed via an added switch with the Demco, and the same mic. The difference was night and day. For the better of course.
    I guess it would've been interesting to check out the splatter with the rig working both ways, but I didn't think of it at the time. I'd still like to know what that device is that's hooked up to the limiter Clipper board. I've never seen anything like that on a sonar FS 2340 and I've seen a lot of those rigs. Thanks for your input. 73
  5. Sonar
    Sonar
    Expand Collapse
    Apr 8, 2016
    886
    316
    Nomadd. Over the years, and beginning many years ago, I heard that if it was up to sonar they would have released and sold the fs 2340 without that Clipper limiter board installed.
    I heard the FCC wasn't happy with what they saw on their test equipment when sonar submitted the fs2340 prior to it's release for sale to the public. Supposedly that's why not limiter/copper board is in there. Most likely folklore, but I wouldn't know for sure. Maybe you could shead some light on that "tall tale." 73
  6. nomadradio
    nomadradio
    Expand Collapse
    Analog Retentive
    Apr 3, 2005
    1,183
    661
    These days, if you want to sell a CB radio, the FCC requires that your production design is "certificated". A made-up word that means you have a certificate of compliance. That comes from a private company's test lab. The FCC in turn "certifies" the lab's capability to make the critical performance measurements on your product. Once the FCC receives a favorable report from the lab you hired, you get your certificate to sell the thing.
    But in the 60s and 70s, the legal term was "Type Accepted". Not sure what the procedure was for that, but sometime between 1973 and 1974 the FCC tightened the rules for type accepting a CB for legal sale. Until then, there was no rule that required a modulation limiter circuit. Weird, but true. Cobra's model 29 mobile radio was originally sold with no limiter at all. Later-production radios had the limiter circuit's parts strung across the solder side of the circuit board. A look at the Sams volume CB56 shows the limiter circuit drawn in dotted lines. The original design lacked the limiter, and the dotted lines showed the components that were "grafted" onto the circuit to do this. But clearly this rule went into effect after Cobra's vendor had begun to build them under the older, looser rules.
    Didn't sound all that good, and the limiter was routinely bypassed on that radio. Later radio designs that included this "feature" from the ground up sounded a LOT better.
    I don't have any inside info about the Sonar radios, but the clipper board appeared in the FS3023 model around this time, best I remember. The older FS-23 model did not have it at all.
    I think.
    But that's the best theory I can come up with.
    #6 nomadradio, Oct 3, 2017
    Sonar likes this.
  7. Tallman
    Tallman
    Expand Collapse
    W9WDX Amateur Radio Member, KW4YJ EXTRA class
    May 1, 2013
    2,065
    1,024
    I worked in companies that required FCC and FAA approval, I worked in the FAA side of things and lent a hand quite regularly on the FCC side on documentation.
    Certificated means the item has been through the wringer electrically and mechanically. Emissions desired and undesirable are noted and documented. Undesirable emissions must be below certain levels and those levels cannot be waived.
    Type Certified means that it is a derivative of an approved "Certified" device that has been through the wringer with only minor differences that do not affect the mechanical construction. If the changes are electrical in nature they must be documented by an outside laboratory and must meet the original specifications.
    Mechanical testing includes mechanical vibration and shock testing along with the mechanical sympathetic resonance. It is an interesting process to witness.
    Sonar and LeapFrog like this.
  8. nomadradio
    nomadradio
    Expand Collapse
    Analog Retentive
    Apr 3, 2005
    1,183
    661
    "Airworthiness" and "Spectrum worthiness" are not quite the same thing.
    If a CB had to pass the FAA tests to be legal, there would not be a single one on the market.
    Fortunately for us, a CB only has to pass electrical tests for stray RF leakage from the various connectors, and purity of the transmit signal. Wattage has to be below the limit, too.
    Used to ponder out loud renting a high-speed video camera, strapping a CB to an old-style paint shaker and seeing how many parts would fly off.
    Seemed like the ideal "final" test for any CB that will be used in a dump truck.
    Sonar likes this.
  9. TM86
    TM86
    Expand Collapse
    Destroyer of radios
    Jul 6, 2014
    160
    89
    Didn't Royce advertise that their radios passed "The paint shaker test"?
    Sonar likes this.
  10. Riverman71
    Riverman71
    Expand Collapse
    Nov 12, 2013
    963
    328
    :D
    Sonar likes this.
  11. Sonar
    Sonar
    Expand Collapse
    Apr 8, 2016
    886
    316
    It's amazing that the CB Hobby was once so tremendous that a company actually advertised their product on television.
    That clip actually brought back memories.
    I absolutely recall seeing that advertisement run.
    Damn I'm old!
    Riverman71 likes this.
Share This Page
