756 Pro III vs. 7300 vs. ????
Discussion in 'Ham Equipment' started by 357, Dec 7, 2017.
  1. 357
    357
    Expand Collapse
    Walkin' the dog
    Sep 12, 2009
    662
    172
    I have an offer to buy my 756 pro 3 and I was wondering what it would take to replace it.
    The 7600 and 7700 are over my budget of $2000CDN.
    Is the 7300 as good as the 756?
    the 7300 has some pretty wimpy PA transistors and the only thing I'd like about it is to be able to put the waterfall on a big monitor but what about audio quality?
    Is it as good as the pro III?
    What do you all think?
    thanks
  2. sp5it
    sp5it
    Expand Collapse
    Master of puppets
    Jul 9, 2009
    774
    309
    From my point of view.
    7300 is small. I prefer big radios with lotsa knobs and buttons. Why? Because when I need to change something quickly I hate digging in 4th menu of 5th menu to do it.
    7300 have only 1 antenna socket. Big disadvantage for me as for rx only antennas user. Can be modded to add rx antenna socket but...
    Mike
    357 likes this.
  3. Road Squawker
    Road Squawker
    Expand Collapse
    Jan 19, 2011
    1,317
    640
    ... and not to mention the issue with the 7300 causing "hot switching" of amplifiers because of incorrect relay design.
    357 likes this.
  4. 2RT307
    2RT307
    Expand Collapse
    Nov 22, 2011
    2,218
    669
    I would tap the IF for the Pro III, buy a RSP-1, and use it with SDR Console 3, SDR Uno, or HDSDR for your panadapter. All of which are free programs. You can use Omni-Rig to tie it together so it sync's with the transceiver. The Pro III is still a really great rig, and I (like Mike) prefer a big base station rig as well.
    http://vk2dag.com/Docs/IC-756Pro3 -Spectrum Scope SDR Mod.pdf
    I have heard both transmit and receive are excellent on the 7300, but even with the SDR and DSP, I think you would be taking a step down.
    73,
    Brett
    357 likes this.
  5. oldgeezer
    oldgeezer
    Expand Collapse
    New Member
    Aug 13, 2017
    56
    16
    I bought a Kenwood TS-590SG & an ICOM IC-7300 at same time. The Kenwood has a far superior receiver. I could not make out weak signal SSB that was clear on the Kenwood. The IC-7300 has such a noisy receiver I had to set the noise reduction on 4 to hear average signal strength SSB signals. Below the AM radio dial the IC-7300 is deaf. The Kenwood shines below the AM radio dial. The IC-7610 is good, but costs $3800.
    357 likes this.
  6. 6meter
    6meter
    Expand Collapse
    Apr 19, 2010
    111
    50
    I ran an 756 pro 2 for a couple of years and really liked it. I liked the performance, ergonomics, size and layout.
    After I got a Flex I let the pro 2 go. Anyhow I've been wanting a smaller size HF rig as a backup that didn't require AC and also for trips. I picked up a 7300 a few weeks back on the $999 deal. So far I really like the 7300.
    For what its worth if I owned a Pro3 I would keep it. If I didn't have it and was looking at new radios I would get the 7300 before I would buy a used pro3.
    357 likes this.
  7. 357
    357
    Expand Collapse
    Walkin' the dog
    Sep 12, 2009
    662
    172
    Thanks for the input guys.
    How about the FTdx3000D?
    I'm really looking at the TTBF option on it as well as the pan adapter output.
  8. oldgeezer
    oldgeezer
    Expand Collapse
    New Member
    Aug 13, 2017
    56
    16
    I never owned a FTDX3000. But per others it is a very quiet receiver & hears very well. Slightly less receiver performance per the specs vs a Kenwood TS-590SG, but I bet you would never hear that difference.
  9. 2RT307
    2RT307
    Expand Collapse
    Nov 22, 2011
    2,218
    669
    I have the FTdx3000 and love it. The receiver is great, in my opinion. The waterfall display is ok, but not as crisp and clear as the Icom displays. I am using the rsp-1 on the rx out port as a panadapter, and it works fantastic. Prices are very low for this rig now. It is a big radio, too!
    73,
    Brett
Share This Page
