I will mail you a proper VR to put in if need be, my thinking tells me it is not the VR anyways.Can I use resistors for the power supply board.. does tr14 and tr15 is on the tx side of the radio?
So you are telling me you think PA mode works as it should?As far as I can tell it's working like it should
Still though, once the audio section is kosher you may have to turn the gain all the way down and have the speaker at least ten feet away!Oh ok. We I use the pa I have to turn the gain way down so it does squeal at all
