Ameritron AL-1500 ..... I purchased this amplifier used, very little use, 4 years old.....Excellent condition and power output.... The inside looks brand new, no dust and no work done inside. It arrived in three different boxes (original Ameritron boxes inside of additional packed boxes). I had to install the U.S. made 3CX1500/8877 tube, and the transformer .......
My problem is that the ALC control will not function with my Icom 7300. Actually, there is not any ALC voltage coming out the ALC jack. Well there is a little..... -270mvdc ~ -290mvdc (-.290vdc).... This is not enough to activate the ALC control.
I removed the ALC board and disconnected one leg of each component for checking. All diodes check good with a diode specific test meter. All capacitors check good with their stated value. And all the resistors check good also.
However, what I did find was the ALC out control adjustment pot (R2) is a 1K ohm pot. According to the schematics and parts list for the AL-1500 and the AL-1200, this pot should be a 100K ohm potentiometer.
Could this be the issue ? Not enough resistance to get enough voltage drop ?
Thanks for any help or assistance ?
