antenna project pdl-II made into a quagi please help antenna qurus!
Discussion in 'Amateur Radio Antennas' started by sob, May 23, 2012.
  1. appaloosaguy
    appaloosaguy
    Expand Collapse
    New Member
    Jul 9, 2017
    I am trying to build a 3 element PDL can you please post the measurements for the wire, linth of the arms and the spacing of the director element?
  2. IRock817
    IRock817
    Expand Collapse
    Oct 29, 2011
    168
    30
    Top secret! Shhhh
    tecnicoloco likes this.
  3. theborg
    theborg
    Expand Collapse
    New Member
    Sep 8, 2016
    9
    antenna.JPG I know this is a long shot but I wonder if anyone knows what this antenna is. I bought it from an older guy who said it was a Realistic from the 1970s. It has 2 sections, 6 feet each, that screw together.
  4. tecnicoloco
    tecnicoloco
    Expand Collapse
    Tweaknician in Training
    Apr 23, 2005
    385
    100
    Archer Crossbow sold by Radio Shack back in the early 80's
    Cat. No. 21-967.This is made of light blue fiberglass
    Back to topic
  5. tecnicoloco
    tecnicoloco
    Expand Collapse
    Apr 23, 2005
    385
    100
    Another Top Secret :unsure:
  6. Marconi
    Marconi
    Expand Collapse
    Usually if I can hear em' I can talk to em'.
    Oct 23, 2005
    5,424
    577
    Appaloosaguy, the regular two element PDL shows to have a driven element wire that is 458" inches total length. That is 9'6" inches per 1/4 wave side or 114" inches. For CB this one is a lot longer than 108" or less inches if used in the middle of 11 meters and using thin wire makes it worse. If you are going for 10 meters you'll need to get out your trusty slide rule.o_O
    I don't know for sure what the reflector length is by reading the Manual, but my copy has a hand written note of the cover page with an arrow pointing to the reflector wire along with a note showing 462.5" inches. That is not much difference but this antenna is inductive and along with the orbital matching setup using a gamma match the 458" inches for the driven element may electrically appear much shorter and that will make the reflector bigger as a %.
    The spacing shows 55.125" inches between the center of the hubs. To be clear the spacing is in the manual.
    As a starter I would make the director hub easily adjustable and start with 55" inches just like R to Dr. If you're lucky and are able to get close to a match with your 3 elements...you might do a couple of short spacing adjustments with the director, making it longer and shorter spacing, and see how it effects the match. You will have to be close with the gammas first however, to really tell.
    It might be best to get the two element working first and then install the 3rd element so you might avoid chasing your tail just trying to get close.
    Tuning this one could be a beast having to tune gammas and not being sure about wire lengths and spacing to boot, much less adding another element where everything could change.
    I read an account of one guy building this idea from scratch, and he spent a long time getting it working right.
    Just remember this antenna, with gamma matching is going to be longer than you might expect and for sure if your using standard formulas.
    Good luck and keep us posted,
Share This Page
