i was wondering on some you have 1 from radio and 2 3 4 ect out of the switch to antenna. Can these be reversed to do 2 3 4 ect radios input to 1 antenna? Curious was looking at some deltas
A switch doesn't know what it is hooked to. 1 in to 4 out or 4 in to 1 out either way works.They work either way. MFJ makes a dual switch that handles many antennas on one side and many transceivers on the other allowing any transceiver to be connected to any antenna.
A little late in the game here but just a comment that the Alpha Delta switches have better isolation between the positions than most other coaxial switches. This is important when choosing a switch for switching different rigs rather than antennas.The Alpha Delta switches are good switches. The 4B is made to work either 4 antennas, 1 radio or 1 antenna, 4 radios. You can run two of them together to choose from 4 and 4. I also use their surge protectors on my transmission lines as they enter the house. All purchased from DXengineering.
