Build a Magnetic Loop?
Discussion in 'Amateur Radio Antennas' started by BenMara, Dec 1, 2017.
  1. BenMara
    BenMara
    Expand Collapse
    Jan 16, 2013
    51
    4
    Recently watched this vid. Now im thinking about adding a magnetic loop to my antenna arsenal (farm).
    What do yall think?
    Current antennas are Hexbeam (20-10m), (OMTA) Offset Multiband Trapless Antenna (vertical 40-10m) and 80m wire fed with window line (50' above ground at feedpoint).
    2RT307 likes this.
  2. sp5it
    sp5it
    Expand Collapse
    Master of puppets
    Jul 9, 2009
    774
    308
    You can't have too many antennas :)
    BenMara and 2RT307 like this.
  3. 2RT307
    2RT307
    Expand Collapse
    Nov 22, 2011
    2,218
    669
    I'm with sp5it. :) I've heard they are great for receiving, especially on 160 where things are so noisy all the time. My coolest antenna I made recently was a tape measure yagi for 2 meters. Ha!
    Let us know how you make out. :)
    73,
    Brett
    BenMara likes this.
  4. BenMara
    BenMara
    Expand Collapse
    Jan 16, 2013
    51
    4
    Only problem i see is the variable capacitor. And to make it 100w+ compliant
  5. BJ radionut
    BJ radionut
    Expand Collapse
    Supporting Member
    May 9, 2008
    1,451
    565
    Yep Commercial Grade vacuum variable...Jennings/Comet/Russian equivalent is about your only options at that power level...100w PEP+ requires pretty high voltage like 5K VDC or possible more depending on construction.
    Then mounting and tuning are other hurdles.
    GL
    All the Best
    Gary
    BenMara likes this.
  6. BenMara
    BenMara
    Expand Collapse
    Jan 16, 2013
    51
    4
  7. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Professional Amateur
    Staff Member
    Apr 6, 2005
    14,362
    5,681
    Better get the 5500 volt rated one and don't run too much power. Vacuum variables really are the way to go with small loop antennas.
    BenMara likes this.
  8. BenMara
    BenMara
    Expand Collapse
    Jan 16, 2013
    51
    4
    Totally agree. i dont plan to run past 100w. 99.999% of the time on any Mag Loop
  9. BJ radionut
    BJ radionut
    Expand Collapse
    Supporting Member
    May 9, 2008
    1,451
    565
    Those are "Air" variables
    These are Vacuum
    http://www.mgs4u.com/RF-Microwave/vacuum-variable-capacitors-500.htm
    https://www.rfparts.com/capacitors/capacitors-vacuumvari/vacummvariable-201to500pf.html
    http://www.ur4ll.net/MLA.jpg http://www.ur4ll.net/#caps3
    [​IMG]
    15-750pF 5KV 35A max dia. 108mm, max len. 200mm (incl shaft)
    (measured capacity is 10-780pF)
    All the Best
    Gary
    BenMara and Captain Kilowatt like this.
  10. BJ radionut
    BJ radionut
    Expand Collapse
    Supporting Member
    May 9, 2008
    1,451
    565
    [​IMG]
    100 watt carrier rated mag loop
  11. BenMara
    BenMara
    Expand Collapse
    Jan 16, 2013
    51
    4
    If i like the 160/80 mag loop performance, Ill most likely build one for 40/20. Can never have too many antennas on the farm.
  12. BenMara
    BenMara
    Expand Collapse
    Jan 16, 2013
    51
    4
    Do you have any online sources for MORE mag loop info? My ARRL antenna books is so limited for Mag Loop antenna...
Share This Page
