Cobra 139xlr, I need help
Ok, try this, desolder the base and collector legs of the driver and final and disconnect them off the main PCB, then key the radio again in SSB, see if the channel lights dim. Let me know how you get on.
~Cheers~
C179 is a tantulum cap back by the finals that will do just what you are having. put an electrolytic in its place of the same UF and voltage. this will work just fine.
~Cheers~
I unhooked the base and collector legs and all lights stay on in SSB and AM, no dimming at all. Seems I have a shorted driver and final, but I would have sworn they checked OK when I pulled them from the radio earlier.
I still have good receive on SSB, but very weak on AM because I am down to my last transistor for TR5, so I left the bad one in for this test.
I can order new NEC 1306 and 1307 from RF Parts, little on the expensive side, but I don't know of any replacements.
There is a resistor on the final that measures 47.7ohms,it goes from the collector to the base, I cannot find it in the Sam's schematic at all, seems to be factory as it has a plastic sleeve over it. But I don't know.
Also there is a 100nf ceramic disc cap going from the emitter leg of the driver to chassis ground, but on the final the same size cap is going from the collector leg to ground, I cannot find these on the schematic either.
Could these be in the wrong place causing the final and driver to cause all these problems?
Thanks ExitThirteen, this is what I found when disconnecting the legs of the driver and final. Please let me know if it is the final and driver causing all my problems, and if the caps and resistor are in the right location for them. If I need to look further let me know.
At least I feel back on the right track.
Thank you very much, Mike
The 47 ohm resistor is part of a factory mod. The "technical bulletins" for the factory mods are shown here.
http://www.cbtricks.com/radios/cobra/139xlr/index.htm
The 47 ohm resistor and the caps are not shown in sams #127 because that volume was published before the service bulletins were issued. The bulletins call for the final bias to set at 15 ma rather that the 70 ma called for in the sams #127 alignment. For more info on this, check out this site.
http://unit399.wixsite.com/858ssb.
Good luck. 73s.
- 399
Reactions: ExitThirteen
Good luck. 73s.
- 399
Thank you 399, I have all the tech bulletins from cbtricks printed out. But cannot find any reference for a cap to go from the collector on the final to chassis ground, or for one to go from the emitter to ground on the driver, although that one can do no harm as the emitter on both the driver and the final are on the PCB ground. But why one from the collector to ground? Right now, I have looked and probably overlooking this, can you reference the number of the bulletin? I found bulletin 1208 referring to the 47 ohm resistor it says from base to ground, mine had been soldered in from base to collector, I think somebody has screwed this all up. My production number is high enough that the only tech bulletins that should have been done after the build is the one referencing the 2 diodes on L3, and that had not been done.
Yes I know about keeping the bias to 15 ma, down from 70 ma. I am going to have to replace the driver and final before I can set any bias though. I am wondering if this is the only problem though.
Thanks, Mike
Well, it may not be the only problem, but this fixes a major problem you were having. You can install a C2166/C1969 driver/final pair and those will work in place of the C1306/C1307, since genuine C1306/C1307's are tough to find. Get the driver/final replaced and key it up again and see if the lights dim again, and let us know how you get on.
~Cheers~
~Cheers~
Will do. I want to thank everyone for all the info and help. I have tracked down new NEC 1306 and 1307 they say were manufactured in the late 70's, I don't know if I should believe it or not though. Kinda pricey but don't have much choice I guess.
Thanks everyone, will post after I get new parts and let everyone know the outcome.
Mike
Also, the 47 ohm resistor you mention is supposed to be soldered from base to ground, so if yours is soldered from base to collector, there's where the problem lies. With that resistor in its current position, it's feeding the base of the transistor with close to 13V.... and that's really bad. That will destroy the transistor. Before you replace the final, make sure that 47 ohm resistor is soldered from base to ground. :)
~Cheers~
~Cheers~
I have the new final and driver on the way. Just to clarify, the 47 ohm resistor will go from base to emitter, which the schematic shows as ground, or should it go to chassis ground?
One more question. Are 1n4148 diodes OK to use for the Tech Bulletin #1210?
I assume, that resistor being in the wrong place is also the cause of TR5 shorting as soon as you key the mic, correct?
I thought this was a virgin radio, but I am going to have to really give it a good look over, some monkey has been in it for the resistor to be in the wrong place.
Thanks, Mike
The 47 ohm resistor should go from base to PCB ground on the final. The capacitor you mention that goes from collector to ground, should go from PCB ground to chassis ground. 1N4148 diodes are fine to use for the bulletin #1210, just make sure to observe polarity per the bulletin and you're good.
Let us know how you get on. :)
~Cheers~
Reactions: 222DBFL
Hello everybody,
I got this off flea bay as parts only- non working and they were right.
I recapped all electrolytics, sprayed all the switches with Deoxit and she roared to life in SSB mode receive, no transmit at all. Still had the stock driver and final, so I pulled them and checked with DMM and they show OK.
Read all the tech bulletins, and my production number was high enough all but one should have been made at the factory. I replaced TR5, a C1730,D26 and D2 and all receive including AM came alive.
Plus I changed out all C1419s for NTE152s. Checked my mic wiring since it is relay switched and all looked good. Plugged it in and as soon as I keyed, it all went dead, changed the fuse and just went ahead and swapped out for all new NTe152s again. Lights came back on and SSB receives but no AM, now when I key up the channel LEDs go out and meter lights go dim and no transmit. I have no idea what caused that to happen.
I know I am fighting different problems, but if someone could tell me or point me in the right directions, it would be greatly appreciated. I am about to pull what little hair out I have left. I just received my Sams copy, but it was printed before all the tech bulletins.
I have another NEC C1730 on its way, but at 7 bucks apiece, I would rather not pop another one.
I am going to replace D26 and D2 again tonight, I have correct voltages on TR5 so hoping it will still be OK, but I have my doubts.
Any help or suggestions will be greatly appreciated, it has never been modded and is bone stock.
Thanks, Mike
Ok seems the vr7 was bad thank you for that.. I have also noticed that if you go to ssb and key the mic the relay wont let go even if dynamike is turn down yet it dont seem to mod on it as well.. I tried different mike no change. Looks to be keying about 15 on ssb .. but dont l ed t go
I bought a Cobra 139xlr on ebay. It had a problem with AM receive but SSB worked fine. I completely recapped the radio. I adjusted TP 7 to 2v. When on AM, when you unkey the mic the voltage on TP 7 gets stuck on 4.65 volts. If you change the selector to SSB and back to AM it will return to 2V and receive works. You have to be on ch24 or lower when you switch to SSB and back. SSB works perfect! I can see the voltage on TP7 change soon as you key up the mic. Any ideas?
    63Sprint has left the room.
