Hello guys by any chance does someone have a Cobra 142 gtl Alignment procedure info?I have all the equipment such as a scope ect...
Thank You SpaceCowboy, is that tr41, or tr40? Or is a tr401 really on the board, I can't see it! tr23 is the largest numbered one i see i have the unit in front of me now.,sam's says to set it to 13.8 volts with the reading off the tr401 emmiter.
TR401 is the 2SD188 NPN in the schematic, thank you SpaceCowboy.|tr401 is the one on the PS board attached to the heat sink.
Its in there behind the VFO chip. Flat against the board IIRC. Took me awhile to find it too. You'll get it . . .Just got my first 142GTL, someone "modded" it (hacked it all up) and measuring at the power at the meter lights and ground I got over 15 volts (I assume someone cranked up the output for more power)
I see the adjustment pot, I can adjust it back down for longevity sake. Where should I probe to make sure the board is getting between 12.5-13.8v because I am having my doubts this is proper place to measure (at the meter lights).
Thank you, also
Is vr6 (am power) directly next to the 1000uf cap?
& about this:
Freq. Counter to tp3 (r101) TP3 is gone? Ripped out?
I cannot find an R101 to save my life!
NO; you don't want to do that.OK got the power supply set @ 13.86 v I can live with that.
VCO i was under the impression this radio used an lc tank oscillator, with caps, resistors, and a transistor pair, obviously i have much to learn, im gonna stare at the board somemore, I need to hook in this 2 wire freq. counter. it will only show when transmitting thats fine, just need a safe pick up point, would the so-239 connector be feesable with a dc blocking cap (I would us a ceramic/mica)
