cobra 2000 gtl need help unlocking the clarifier .
screwup504
Jan 18, 2014
2
ok what am i doing wrong . Hear is what I have done . removed R 44 . r 174 and r 175 jumped out . took brown wire off of fvl and took the red wire on the other side of the fvl and moved it to pin #1 of ic4 ... and now on rx im on 27.1695 and tx 27.1835 when the radio is in chanel 19 . this is where i got this info that is not working right . I know i will ned to retune once im finish but it will not retune 3 chanels off lol http://www.cbtricks.com/pub/secret_cb/index.htm
are you sure you have the wire soldered to IC4 in the proper place. you should have 8 volts on it constant.it has been years since I did one so make sure you have a constant voltage on the one wire. without it your mod goes waky.
Reactions: screwup504
The two suspiciously-tiny diodes D52 and D75 alongside the 11.3258 crystal are in series, and steer the transmit-only voltage to the PLL crystal. Pulling one end of either one will probably fix the trouble you're seeing.
A jumper across D51 only serves to increase the max frequency you can get with the clarifier all the way to the right. But not a whole lot.
Bypassing or removing resistors are not necessary to make the clarifier mod work; but it will make it slide farther. But at the cost of where the clarifier gets centered. Once extra slide is done, the clarifier will center around the 2 o'clock position. If you don't mess with the resistors, it will align at 12 o'clock as I prefer.
Thanks for all the help . I put it back stock then removed d52 and r44, put yellow wire from cvl to pc ground and red wire to ic4 3rd pin from the back of the radio and removed brown wire from fvl and BAM it worked . That is where i was messing up i was putting red wire 3rd pin from the front on ic4 lol. I have already dropped it back off to its owner but i want to say it was sliding 5kc up and down like this ,
    63Sprint has left the room.
