cobra 29 wx nw st
Discussion in 'General CB Services Discussion' started by randl, Jun 18, 2017.
  1. randl
    randl
    Expand Collapse
    New Member
    Jun 14, 2017
    5
    2
    I received a cobra 29 with burnt out finals. I put a mosfet kit in it. The IC4 audio chip gets very hot. I replaced the chip and it still gets hot. I checked the solder joints and they look good. I don't know if the IC4 is getting hot from what I did or from the previous damage. Any ideas on where to go next?? The IC4 chip has 12.6 volts across the the terminals. Is this to high?//
  2. Bow
    Bow
    Expand Collapse
    Bastard Modulation
    Aug 13, 2008
    127
    34
    You replaced the IC, did you put the thermo-grease on it before mounting it?
    You need a copy of this:
    http://www.cbtricks.com/radios/cobr..._st/graphics/29ltd-st_29wx-st_sm_pg1_pg11.pdf
    http://www.cbtricks.com/radios/cobr...st/graphics/29ltd-st_29wx-st_sm_pg12_pg34.pdf
    it has the voltage charts in the Second link
    And he is some more 29 porn for you...
    http://www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/graphics/cobra_29ltdwx-st_29ltd_sch.pdf
    randl likes this.
  3. randl
    randl
    Expand Collapse
    New Member
    Jun 14, 2017
    5
    2
    Yes, I did put the thermo grease on them. Thanks for the links!!
    Bow likes this.
  4. Bow
    Bow
    Expand Collapse
    Bastard Modulation
    Aug 13, 2008
    127
    34
    Yes sir!
    Hope it is helpful.
    The Good news is, its a 29.... there is SSSSOOOO Much information on those, should be a great project to get going again.
    I'm currently playing with an Old Superstar 3900, and a SBE Catalina II 23 channel!
    Robert Mazzochi and randl like this.
  5. randl
    randl
    Expand Collapse
    New Member
    Jun 14, 2017
    5
    2
    This is the first radio I am working on. It was a freebee. It was not working when I got it.
    Bow likes this.
  6. Bow
    Bow
    Expand Collapse
    Bastard Modulation
    Aug 13, 2008
    127
    34
    Well, there you go.
    If you play your cards right, you might get a great radio for the price of a couple components, your time, and your sweat.
    Post up your findings as you go and I'm sure someone else may chime in with ideas
    randl likes this.
  7. randl
    randl
    Expand Collapse
    New Member
    Jun 14, 2017
    5
    2
    Yes, I am determined.
    It is frustrating. I found out that with the different models of cobra 29 that the wire diagrams and audio chips are different. I am having a hard time finding the right wire diagram for my model. Unfortunately, I don't have to much spare time. But, I will keep posting what I find.
  8. sonoma
    sonoma
    Expand Collapse
    Sep 14, 2005
    1,311
    446
    here is about every radio that cobra has put out. even has a wiring diagram for the 29radios. see if you can find what you need here. shows all the chips used by cobra. I have used this info for about every cobra 29 I have ran across. it also has the info for the newest cobra 29 radios. I put the wiring diagram here for you also so you do not over look it.
    http://downloads.cobra.com/CB/Models/29-SERIES/
    http://downloads.cobra.com/CB/Models/29-SERIES/29LTDwiring.pdf
    randl likes this.
  9. randl
    randl
    Expand Collapse
    New Member
    Jun 14, 2017
    5
    2
    Thanks very much! It is very helpful.
    The one thing I have not been able to figure out yet is where it shows capacitor C42. On my radio it is actually C41. And where the scamatics show C44 mine is C39 no matter what year the radio is.
    I will keep posting. This is a slow works in progress for me.
Share This Page
