Cobra148gtl final&bias
Discussion in 'General CB Services Discussion' started by kaos513, Nov 13, 2017.
  1. kaos513
    kaos513
    Expand Collapse
    Apr 10, 2014
    858
    109
    my klein meter goes up to 700mA
  2. kaos513
    kaos513
    Expand Collapse
    Apr 10, 2014
    858
    109
    Meter set to 20ma tp8 i get 4.72ma
    Meter set to 200ma tp7 i get 191.5 ma
  3. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,377
    2,133
    Driver should be set to 25mA and the final to 50mA.
  4. kaos513
    kaos513
    Expand Collapse
    Apr 10, 2014
    858
    109
    blew the dust out of the old techtronics bench meter below is a picture of my reading for the final bias is that correct guys ?
    Robb likes this.
  5. kaos513
    kaos513
    Expand Collapse
    Apr 10, 2014
    858
    109
    Here is my driver bias readings below is a pictire
    Robb likes this.
  6. kaos513
    kaos513
    Expand Collapse
    Apr 10, 2014
    858
    109
    so the pictures above are correct readings ?
  7. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,377
    2,133
    So long as that is the mA scale; then yes.
    Nice gear!
  8. kaos513
    kaos513
    Expand Collapse
    Apr 10, 2014
    858
    109
    thanks forgot i had this gear in my closet dusted it off and started using it .
  9. kaos513
    kaos513
    Expand Collapse
    Apr 10, 2014
    858
    109
    Im just looking to see if anyone can confirm these readings are correct.
  10. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,377
    2,133
    #25 Robb, Nov 19, 2017
  11. loosecannon
    loosecannon
    Expand Collapse
    Mar 9, 2006
    2,693
    922
    Kaos, everything in your picture looks correct, but not knowing how the display works on that meter, i would set the range to the 200m setting and make sure that it still displays a "25" and doesn't show a "1" which would indicate an over range condition.
    you have it set to the 2 amp range in the pictures.
    If it were my meter, i would set both driver and final using the 200milliamp range.
  12. kaos513
    kaos513
    Expand Collapse
    Apr 10, 2014
    858
    109
    ill will report my results soon thanks.
    #27 kaos513, Nov 20, 2017
  13. kaos513
    kaos513
    Expand Collapse
    Apr 10, 2014
    858
    109
    something strange i encountered i believe this 148gtl has a wierd bias driver adjustment. my black lead is attached to purple wire and red is attched to ground of radio, that is how i adjusting the bias strange.all my othher radios i have done are in 2000m range and have had no issues strange .
  14. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,377
    2,133
    No; your red wire should be attached to one of the two posts.
    Didn't you watch my video?
  15. kaos513
    kaos513
    Expand Collapse
    Apr 10, 2014
    858
    109
    i know that but this is the only radio i encountered this issue will not work on 2000m unless i ground red wire.
Share This Page
