For saving space, and some experimenting, I've been thinking about creating a compact 80 and 40 meter dipole pair of antennas. I was considering using sections of heavy paper carpet center tubes, winding the legs of the dipole on them and gluing the wire in place. Then, I'd cover the whole thing with clear shellac to waterproof it. For materials, I have a 30mHz balun, 14 gauge stranded wire with insulation, and RG-8 coax. My big question to everyone is: Will this thing work as pictured in my mind? It would resemble a "T" when finished, would be about 4' long, each side of the dipole would be wound in a tight coil around the tube except for the last foot or two. Am I missing something obvious here while thinking this up? Would it be directional and, if high enough, transmit as far as a normal, strung-out dipole? Any input positive or negative would be appreciated!---Thanks, Rick
