Elecraft KX3 Operating Tip - VFO Lock
Ham Radio Nerd
Apr 14, 2002
9,194
1,674
283
Wayne from Elecraft has started posting operating tips on the new KX3 that may not be obvious from reading the manual. Here's the first in the series:
VFO LOCK
Locking the VFO can be useful when operating mobile or portable, or if
you just want to stay parked on one frequency for a long time and
don't want to accidentally change it.
The KX3 doesn't have a dedicated VFO lock control. To lock it, hold
the KHZ switch in for about 3 seconds. You'll hear a beep if switch
tones are enabled (MENU:SW TONE), and a lock icon will appear above
the "A" on the LCD.
This locks only VFO A, not VFO B. To lock VFO B, first swap it to VFO
A (using the A/B switch), then lock, then swap it back. The VFO B lock
icon will now appear below the "B". You can lock both VFOs if required.
To unlock VFO A, tap RATE or do normal hold of KHZ (about 1/2 second).
If you only want to slow the VFO down a bit rather than lock it, you
can increase the friction. See page 24 of the current KX3 owner's
manual. You can also decrease the number of VFO counts per knob
revolution (see MENU:VFO CTS).
73,
Wayne
N6KR
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
