Fire tower
any light weight vertical, A99 or I2K you can assemble it in the tower and install it in just a few minutes, when you are done you can remove disassemble and take it with you, should work great and what a deal being able to use the structure.
I would leave the antenna and coax there permanent and connect to the mobile when you wanted to play radio, those steps will give you a work out for sure.
Be nice to have a hand held walkie talkie to use up on that tower, just to see what contacts you could make.
A magnum 1012 handheld would be sweet up there as well!! I would think that at that height you could make some contacts with not much power!! Sweet place no doubt!(y)
Reactions: wavrider
    63Sprint has left the room.
