Consider, for measuring equipment such as this, the standard is to take the last displayed digit and make it + or - 1. Also, this counter probably uses a circuit design and components similar to those in most CB radios, so it's stability is going to fluctuate as much as 3 on that last digit.
So, now your reading can vary from the actual frequency of the radio by as much as 4 units on that last digit, which is in 100s of Hz.
Assuming the calibration of the counter is dead on, your reading is 600 Hz low, but your actual frequency could be only 200 Hz low, which is again within the design specification of this class of radio. Of course, it could also be off as much in the opposite direction.
Try the measurement again in the summer and see how much it changes.
The relative magnetic flux of the earth relative to the sun, the lunar alignment of the planets, temperature and humility all affect these measurements.
