This Glen Martin antenna track system is diffrent
then the hazer. It has two tracks that fasten onto
the outside of the 45G tower face. This allows
you to have guy wires hooked up on 90ft of tower.
When you crank the antenna up the tower you can drop a set of the guys and then when you are pass
them hook them back up and keep going up the tower. I have the manual and all hardware which
is mostly stainless for attaching the aluminum
track.Nice system if you want to go higher then
50ft the regular Hazer goes. Have manual too.
No other company makes a design like this.
This is the top of the line in antenna lift systems. Was $2900 reduced it down to $2500
It will make your antenna work easy.
Bring your yagi to the ground and walk around it.
Man how easy is that. Better then a crankup since
they only come down to around 22ft and if they tiltover its still not easy and that safe to reach
the center elements. I know I used to have one.
I got out of ham radio and don't need this system.
