HELP hifi am audio in a cybernet pll02a clone like ge 3-5819a or rca 14t305
kc2koj
Jun 14, 2012
17
can someone help me out and take a look at this schematic and tell what to change out or to bypass to get fuller hifi tx am audio... looking for loud natural with good range for bass and treble ....what caps should I change or would I be better off trying to inject mic input at a different point ....Thanks ^^ ab v c^^
  • 14t260_70_14t303_4_5_pg29_30.pdf
  • 14t260_70_14t303_4_5_pg2_pg18.pdf
  • hygain_2_3_2702_2703_sm_pg01_pg29.pdf
  • 14t260_70_14t303_4_5_pg35_36.pdf
  • 14t260_70_14t303_4_5_pg37_pg45.pdf
#2 08-31-2013, 09:37 AM
JoeDirt
Senior Member
iTrader: (1) Join Date: Dec 2008
C94 is what you want to bypass the audio amplifier, your only limiting factor will be the audio transformer.
#3 09-05-2013, 10:41 AM
kc2koj
Junior Member
iTrader: (0) Join Date: Jun 2012
can you please explain .....what should i do ?????? should i pull c94 and just bridge soder points... or inject mic input there... or would i be better off changing value of c94 thanks
    63Sprint has left the room.
