I am an 11 meter idiot. With that said, I kinda see a bright light off in the distance. I am looking to setup a base for 11 and I would like to try a real transceiver. What should I look for used around $400? Any other words of wisdom? Thanks
No worries, I expected a response like that from you. Thanks for the pointer.If you run AM only then skip the ham gear and get a cobra 29
If that is the worst jab I get up here in the ham section, I'm good with that. I have zero use for am on a base. I really don't see any reason to run an export as a base. I'm just looking to expand.
Sorry you took my message as a personal attack, I will remember that in the future.No worries, I expected a response like that from you. Thanks for the pointer.
I really like that IC-718, and it looks like it can be had new for $650 with DSP, and the mars mod is pretty simple.With 400$ to spend I would look for IC-718 with DSP module, TS-450, FT-890.
Mike
That FT450D is starting to get a little pricey for me, but I will consider it. I thought I would start at $400 because everything around here exceeds our budget by a considerable margin.Take a look at the Yaesu FT450D. The new ones cost a little more than the Icom but the Yaesu is a much nicer radio and better lay out over the new version Icom with DSP.
You did suggest a budget of $400 which limits your options to used radios over 10 years old.
One thing you will find with Ham guys and used equipment is they want good deals when they are buying but want to recoup nearly all their money back when selling. Having said that I would expect to see a used Yaesu 450D to sell for no less than $600, maybe a little less for the older non-DSP model Yaesu 450. About the same for the Icom 718 for both DSP and non-DSP models.
Any idea what the quality is like on the Alinco? Will it be running strong in 20 years like the other 3 brands?There's also the Alinco DX-SR8T. It sells for around $500 new so you should be able to pick up a used one within your budget.
https://www.gigaparts.com/alinco-dx-sr8t.html
