Icom IC-7300 HF Transceiver Review
Discussion in 'Product Reviews' started by Moleculo, Apr 3, 2016.
  1. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,801
    799
    Review update #4 posted above.
  2. Sonar
    Sonar
    Expand Collapse
    Apr 8, 2016
    560
    188
    Heard one this evening on 38lsb. A local in southern nj or eastern penn. Can't recall his handle/numbers but, I must say with the supplied icom hand mic the transceiver sounedd very nice
    Thanks for the first part of your review. Very informative. And the transceiver seems to be easy to use for the first time HF owner and at $1500 seems like a deal. Used 756 for $1000-$1300 or a brand new rig for $500 more. A no brained IMO. If the general coverage mod can be done for 27 MHz via the menu as opposed to going inside the rig is a plus as I'm sure the important warranty stays intact. I'm not sure if I'd void the warranty. New rig designs sometimes have bugs which require a return to place of purchase or an authorized tec for warranty repairs. Looking forward to your followup.. Thanks
  3. Road Squawker
    Road Squawker
    Expand Collapse
    Jan 19, 2011
    1,164
    503
    it can not be done via the menu.
    depending on what you want, 1, 2, or 3 diodes must be opened.
    Sonar likes this.
  4. camaro1
    camaro1
    Expand Collapse
    Nov 2, 2012
    955
    309
    LeapFrog likes this.
  5. Sonar
    Sonar
    Expand Collapse
    Apr 8, 2016
    560
    188
    I'd hate to purchase one, do the 27mrz mod then find out there's a design flaw. The warranties gone and you've voided it. As long as you don't have deep pockets and short arm's you're good.
    I guess that's one of the problems with purchasing an HF and insisting on having it operate on 11 meters.
    If I'm correct there are several hf's that can be programmed through the trancevers menu.
    I looked for a list of those particular rigs but couldn't find one..
    Steve_Buckeye likes this.
  6. camaro1
    camaro1
    Expand Collapse
    Nov 2, 2012
    955
    309
    I don't think they can deny warranty work due to mars mod, I once sent in an icom 7200 for warranty and they never said a word about the mars mod,,,, now if you screw up your radio doing the mod then your SOL
    Sonar likes this.
  7. Steve_Buckeye
    Steve_Buckeye
    Expand Collapse
    Nov 12, 2015
    48
    26
    Try to find a used ICOM IC-718, they are about $400 at swap meets. These just need a resister remove to expand the channels and are a good radio.
    Sonar likes this.
  8. RatsoW8
    RatsoW8
    Expand Collapse
    Supporting Member, W9WDX ARC Member - WD8T
    Nov 3, 2009
    3,086
    1,320
    Let's try to keep this thread on the topic of the IC-7300. One it wanders it won't come back :)
    Road Squawker, 2RT307 and camaro1 like this.
  9. n8fgb
    n8fgb
    Expand Collapse
    May 18, 2008
    616
    170
    Is this a different IC 718, mine has no channels or selector. It does have a VFO, A and B.
    Rich
  10. BBB
    BBB
    Expand Collapse
    Jan 17, 2012
    696
    335
    I think I'm seeing two (2) Mitsubishi RD70HVF1C (VHF/UHF) MOSFETs in the final PA section schematic. They are rated at 70 watts each.
    https://www.rfparts.com/rftransistors/transistor-rd/rd70hvf1.html
    Hmm, interesting that they are not using a pair of the standard 100 watt RD100HHF1 (HF) MOSFETs. To save $10...wow? Maybe for the 50 MHz coverage?
    https://www.rfparts.com/rftransistors/transistor-rd/rd100hhf1.html
    #40 BBB, Apr 19, 2016
  11. Steve_Buckeye
    Steve_Buckeye
    Expand Collapse
    Nov 12, 2015
    48
    26
    exactly, spin the VFO to 27.385 LSB or you favorite channel,
  12. Steve_Buckeye
    Steve_Buckeye
    Expand Collapse
    Nov 12, 2015
    48
    26
    Sorry!
  13. Grant Aldrich
    Grant Aldrich
    Expand Collapse
    New Member
    Apr 16, 2016
    4
    3
    Thanks for an awesome review. I own an IC-7100 but this has so many other necessities.
  14. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,801
    799
    New Update #5 posted above.
    #44 Moleculo, Apr 22, 2016
  15. Jay Mojave
    Jay Mojave
    Expand Collapse
    Nov 17, 2015
    27
    Hello Moleculo: How does this Icom 7300 say compare with the 746 / 746 Pro radios in having the ability / selectivity to reject near by frequency strong stations, and opposite side band stations on the same frequency? Not a bad price for a new design. Great review.
    Hope all is well.
: Icom IC-7300
Share This Page
