IRF520 vs IRF523
carioux2008
New Member
Sep 14, 2016
A coworker of mine has a Cobra 29LX with the IRF520 MOSFET modification. Well, it seems to have stopped working and I was wondering if I could use the IRF523 mosfet in its place (and retune of course). The biggest difference I see is that the breakdown voltage is lower (80v vs 100v) and the drain current is slightly lower. I woudl suspect that the drain current will lower the overall output of the radio, but honestly, i dont really care about that. just want to get him running again.
What effects will the 523 have over the 520 thats in there already?
The IRF520,521,522 and 523 all share the same Fairchild data sheet. Couldn't find the original one from International Rectifier. Only difference I can see is with the voltage and current rating. 520 is listed as 100 Volts and 8 Amps. The 523 shows 60 Volts and 7 Amps. Don't think that will be important in a 12-Volt radio.
The all-important switching speed doesn't appear to be different, so I'd guess that it will work. Just don't know how to predict how well it will work.
    63Sprint has left the room.
