Is a Magnum 257HP an overkill for a Texas Star 667V?
Discussion in 'General CB Services Discussion' started by Turbo T, Feb 21, 2013.
  1. Turbo T
    Turbo T
    Expand Collapse
    Certified CB Rambo
    Feb 2, 2011
    938
    92
    Thought I'd ask. I'm wanting to get an amp for my 257HP. I see the 667V is a 500/650 watt amp. But isn't the knob on the front so you can adjust the sensitivity of the input power?
    Or would my 257HP be too much for a 667V?
  2. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,377
    2,134
  3. Bundy
    Bundy
    Expand Collapse
    Tired and broke
    Feb 16, 2009
    252
    83
    That is a great link Robb, thanks
    #3 Bundy, Feb 21, 2013
  4. 2RT307
    2RT307
    Expand Collapse
    Nov 22, 2011
    2,246
    687
    Yes, it is overkill. Keep the variable out of the mix, and go with the DX500 to run with that rig (or any other one you want). Will make a nice setup with strong output.
    73,
    RT307
  5. Turbo T
    Turbo T
    Expand Collapse
    Certified CB Rambo
    Feb 2, 2011
    938
    92
    Ok then is the 667V really only good for a 4 watt rig? Also when it was showing the 20 watts on that Texas Star page, is that modulation power or carrier power.....? Also what's so bad about the variable powered amps?
  6. space cowboy
    space cowboy
    Expand Collapse
    Quack Quack
    Oct 16, 2012
    1,369
    431
    just set it for enough dead key to click on the relays and swing to 20W pep with your variable power knob on the radio as low as it will go. turn on the amp, turn the radio output as low as it can go. amp off, turn up the radio.
    from what I've read, the variable pot burns out.
  7. AudioShockwav
    AudioShockwav
    Expand Collapse
    Extraterrestrial Admin
    Staff Member
    Apr 6, 2005
    5,400
    1,100
    IMHO get the 500, with that radio you do not need the driver in the 667, your radio will work fine with the 500.
    You have enough radio to get the Max power out of the 4, 2879`s with out feeding extra current to the drivers.
    The Dial-a-watt uses a 2 watt variable, pressing the green dial-a-watt button also inserts a 75 ohm 4 watt metal oxide resistor "pad" for protecting the variable.
    More often than not they get dirty, it is a small carbon track inside and they just do not hold up well twisting them back and forth, if you are buying new, skip it and get the 4 button 500 and use the radio to control the drive power.
    If you are buying used and it is a V model, just run the amp with the red button in and again control the drive with the radio.
    For SSB just use the Yellow delay button.
  8. n0zna
    n0zna
    Expand Collapse
    Digital master
    Nov 3, 2008
    1,256
    153
    the 257hp is a 75 wtt radio and to much for the tx667 and tx500...you need a amp that will take 100 wtt drive like tx1200 or tx 1600...the 257hp is way to much for the smaller tx star amps,even if you turn it down it will still peak to much,73 de JW
  9. Mudfoot
    Mudfoot
    Expand Collapse
    Jun 17, 2009
    8,170
    2,537
    No he doesn't.
  10. 9C1Driver
    9C1Driver
    Expand Collapse
    Aug 13, 2008
    2,924
    694
    Holy crap, I see I am way late on this but I still have to say WOW. A 257 HP would blow the holy he!! out of a 667. Get the TS500V and your good to go.
  11. RADIOOMAN
    RADIOOMAN
    Expand Collapse
    Jun 1, 2012
    428
    53
    I would recommend a straight 4 pill or straight 8 pill.
    No driver stage needed.
  12. Turbo T
    Turbo T
    Expand Collapse
    Certified CB Rambo
    Feb 2, 2011
    938
    92
    Thanks, guess I'll take my eyes off the 667V and keep the hunt out for a 4 pill then.
    Are there any other amps besides Texas Star and maybe the TNT/Midnight Special line to look for? Going to be using the 257 on both AM and SSB.
  13. ExitThirteen
    ExitThirteen
    Expand Collapse
    Grumpy and Cranky
    Apr 18, 2008
    1,605
    866
    You can use any straight 4 pill as long as it's biased for SSB use. If you're wanting something already biased out of the box, the TS-500 would be your best bet. If you don't mind sending it to someone to have the biasing installed, you can even go with the Class C straight 4 pills, like Davemade, X-Force, etc.
    The biggest key is to make sure it's AB biased for clean SSB signals.
    If you get a TS-500, make sure to get the 4 button version and not the variable, as high amounts of PEP wattage will burn out the variable pot if you run the variable anywhere other than wide open.
    Good luck!
    ~Cheers~
  14. Turbo T
    Turbo T
    Expand Collapse
    Certified CB Rambo
    Feb 2, 2011
    938
    92
    How about this one for my 257HP? I read this is a 4 pill amp with 2879's in it....
    [​IMG]
  15. ExitThirteen
    ExitThirteen
    Expand Collapse
    Grumpy and Cranky
    Apr 18, 2008
    1,605
    866
    If you detune the Magnum a lil bit, and get a tech to properly bias the transistors in that amp, that'd work fine. Don't see why it wouldn't work.
    (edit) You might not have to detune the Magnum... it depends on how the input transformers are wound on that amp... I don't know specs of the Midnight Specials offhand. They might be setup to run a 100W driver into them and be ok.
    ~Cheers~
Share This Page
