Just starting
OK I bought the PL-880. Listening to SW is sporadic, sometimes strong. Need an antenna. I can run from the house 60' to a tree, then another 20' to enter the room and another 15' to the radio. Can I use galv, unshielded wire (#9) then switch over to a shielded wire when it enters the house and lastly how should it connect to the radio (specifically)? If I need to run shielded can I run the galv. wire as a guide wire along the shielded? If not what size shielded wire and should it be copper and should it run continuous from tree to radio? THANX
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
