Kenwood TH-D72 failures
Discussion in 'Ham Equipment' started by Moleculo, Apr 18, 2011.
  1. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,817
    826
    I've seen quite a few reports of the Kenwood TH-D72 having problems where the transmit output power drops to either a very low level or nothing at all. I haven't come across any cause for the failures yet, so I'm unsure if there is a permanent fix yet.
    The part failing is the driver FET Q214 and the part number is B51-8944-00.
    Mine has not failed, but I'm curious if anyone else has had this problem or has any other information?
  2. Adrian Ramirez L
    Adrian Ramirez L
    Expand Collapse
    May 9, 2011
    6
    Kenwood TH-D72 No audio
    Dear Moleculo,
    Greetings from Costa Rica.
    Thanks for your review on Kenwood TH-D72
    I now own one. The audio went out. I resest it fully and there is still no audio. I begin to think the speaker is broke.
    Is that possible???
    Everything works and if I connect an external mic/speaker, I can hear everything.
    Thanks,
    Adrian
  3. Qwazyone
    Qwazyone
    Expand Collapse
    Jan 25, 2009
    294
    6
    It may that a wire broke or bad solder joint caused the audio problem, but it could be caused by the external speaker connector also
  4. k7wwa
    k7wwa
    Expand Collapse
    Jun 9, 2011
    Yes, it's true along with failure of the built-in speaker. In less than 1 week my RX audio quit. I called tech support and he asked if I had a remote speaker/mike. When my remote speaker/mike arrived I tried it and good RX audio. However 2 weeks later max TX power U & V was 100mw as measured on a good service monitor. Off to Kenwood for service ad repair.
    George
  5. Adrian Ramirez L
    Adrian Ramirez L
    Expand Collapse
    May 9, 2011
    6
    Problem solved!!!
    Dear Friends,
    This past Monday the speaker for my Kenwood finally arrived here in Costa Rica. Opened up, took away the oldone and set up the new one. Listo!!!!, it is working now. I got the new speaker from PACPARTS.COM Part Number T07-0266-25. I hope this helps!!
  6. n0zna
    n0zna
    Expand Collapse
    Digital master
    Nov 3, 2008
    1,256
    153
    Whats up with all the new radios acting up.Never heard of that till the last few years.I have a ts520 i got years ago no problem,i have a frend that got a new ft100d,no problems.I ordered a new rci2950,i had to send it back the same day,40 wt carrier on ssb.A frend got a new ic7000 it didnt even light up.Radios use to last for years,i have a Siltronix1011d i got new i think in 1982,same tubes works like it did when i got it.73s de JW
  7. lukjoly
    lukjoly
    Expand Collapse
    Sep 13, 2012
    3
    Hi,
    I've go t a D72 with max tx output of 500mW....I can't figure out what is the problem.Can you better detail where this Q214 is located....without a service manual is hard
    thx
  8. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,817
    826
    HRO has the service manual for sale - it's $25: http://www.hamradio.com/detail.cfm?pid=H0-011346
  9. s55db
    s55db
    Expand Collapse
    Oct 20, 2010
    20
    Mine developed this error as well. But only on VHF. That is why it took me so long to notice. All FM communications were over UHF, only APRS on VHF. But it was weird that only two packets from the top of the hill were picked up by gateways :D
    Put it in for a repair, will post follow up when I get it back.
Share This Page
