kenwood ts-440s 11mtr mods?
Discussion in 'Ham Equipment' started by Rogerbird1, Oct 25, 2002.
  1. Road Squawker
    Road Squawker
    Expand Collapse
    Jan 19, 2011
    1,328
    645
    Gee,.... was wonderin what happened to you
  2. Tallman
    Tallman
    Expand Collapse
    W9WDX Amateur Radio Member, KW4YJ EXTRA class
    May 1, 2013
    2,065
    1,024
    When I see a thread for modifications on a ham radio I'll read it and maybe reply to it as well. The Kenwood radios are often overlooked because of Yaesu and Icom being cheaper these days. I bought a TS-440 for $100.00 and was surprised at how good it sounded.
    It is fully functional and I use it mobile from time to time.
  3. mrbooker
    mrbooker
    Expand Collapse
    Dec 28, 2011
    3
    I have two ts 440's, a ts-850 and a ts-50 and all of them talked on 11 meters when I bought them. My ts-50 would not talk AM on 11 meters. Reports said it sounded really bad. I went into the menu and turned the audio down to "low" and turned the power to 10 watts and that worked great.
    I would suggest running lower power and audio with any of the HF rigs. I talk mostly SSB on 11 meters.
  4. Paul-W5lz
    Paul-W5lz
    Expand Collapse
    Jul 12, 2017
    90
    46
    I think you will find that with Kenwood radios the max power on AM is 1/4 of it's rated power on SSB. There's a very good reason for that and you gain nothing by going over that power level. They can certainly be modified to do more than the 25% of max, but there'$ a penalty for it!
    Another hint for Kenwoods is concerning the processor. 'Crack' the thing open -barely- and don't every go very high with it. It is very 'touchy'.
  5. BJ radionut
    BJ radionut
    Expand Collapse
    Supporting Member
    May 9, 2008
    1,481
    593
    Doc is right a 100W SSB rig...max carrier on AM (Ancient Modulation) is MAX 25 watts...NO Prostrasher (leave it OFF) and audio set to where it just tickles movement in the ALC range...Then try it...other wise it will sound like you have your head and Mic in a Fishbowl full of water:LOL:
    All the Best
    Gary
Share This Page
