Lazybones is out of the closet
Lazybones1222
Apr 6, 2005
948
Tampa Bay Florida
No no no - not THAT..... I am no longer JUST a renegade CB operator, I am now a Tech Class Ham operator. I know - snickers abound. Plan on the general in a few weeks.
Later,
CCOL
CONGRADS JEFF!!! Hope to hear you on soon...start re-tweaking those antennas for 10m's and get up a few dipoles if you can... you kick open the door to more RADIOFUN...welcome abroad.(y)
All the Best
BJ
Hello guys,,,I was thinking of taking my Ham test (no code) at the next
coming ham fest.Just curious,How many questions is on the new (no code)
test??? I probably wont jump right into it right away.I understand the
equiptment is alot more expensive,that our little cb hobby stuff.But
id like to go ahead and get the license away,just to say i have them.
Congrats to you as well Jeff!:cool: Its good to hear your'e also going to upgrade.;) BTW whats your call.:confused:
Pathfinder-there are 35 questions on the Element 2 Tech Exam. 74% is a pass. Get some study material and take the plunge! (y)It's really not that difficult.:rolleyes:You can take practice tests from the current question pool for Element 2 (Tech), 3 (General) and 4(Extra) at Eham.com and QRZ.com to name a few. Study the material and take the tests online and when you can score in the upper 80's/low 90's you should be ready for the actual test. It's important that you understand the material so that if you come to a question you are unsure of at least you will be able to use the process of elimination to get a correct answer.
Study hard and Good Luck!
Wayne C.
I thought there are more like 175 questions give or take a few ........but it's done by pulling 35 questions for the test (Question pool).Either way
it's not that hard. good luck
...start re-tweaking those antennas for 10m's... you kick open the door to more RADIOFUN...welcome abroad.(y)
All the Best
BJ
he doesn't have to retweak for 10m.....sounds as good there as 27.385 LSB & his ole stomping channel....have talked to him on all 3 ;-)
