Maldol MH-511?
Discussion in 'Ham Equipment' started by Brandon1, Mar 29, 2010.
  1. Brandon1
    Brandon1
    Expand Collapse
    Mar 22, 2010
    41
    Maldol MH-511 TriBand HT Antenna
    Does anyone use this antenna? The reviews say that it is about the same as the stock antenna, which is fine for my application. Will it even increase performace, or does it stay the same?
    I would be using this simply when I take my radio on my hip. I plan on keeping another HT antenna if I need to hit some farther off repeaters.
    Thanks!
  2. Shockwave
    Shockwave
    Expand Collapse
    Sep 19, 2009
    2,540
    760
    I have the MH-511 and really like the antenna. It does not work as good as the stock Yaesu antenna and certainly not better. It's beauty is the low profile with the ability to work reasonable strength repeaters or very close simplex. It was closest to the performance of the stock antenna on 2 meters but still weaker then the stock antenna. Was a little weaker on 440. Much less signal on 6 meters and deaf on 800 MHz if you monitor there. If you're using it to work your local repeaters it's perfect.
Share This Page
