Messenger M4V Best Operating Voltage?
Discussion in 'Amplifiers' started by kd4e, Apr 21, 2009.
  1. kd4e
    kd4e
    Expand Collapse
    Jun 24, 2008
    21
    What is the best operating voltage for a Messenger M4V?
    Mine has eight MRF-455's in the output instead of the 1446's.
    I have seen references from 12V to 17V, 17V seems too high. I am not as concerned with absolute maximum output as I am to protect the amp and to use the highest safe voltage in order to keep the current down some.
    I need to decide to either use several large deep-cycle batteries with a float charger or get a large AC-DC power supply.
    Also, if/when I use this mobile what secondary battery and other modifications should I make to my 1996 Chevy 1500 van to handle this amp? Upgraded alternator?
    Thanks! doc
  2. mackmobile43
    mackmobile43
    Expand Collapse
    Jock Supporter
    Feb 11, 2008
    6,715
    375
    13.8 volts, you might add another battery if you like and an alternator capable of supplying atleast 120 amps.
  3. kd4e
    kd4e
    Expand Collapse
    Jun 24, 2008
    21
    So even base where a higher operating voltage would be convenient 13.8 is optimum?
    OK re. the extra battery (perhaps an Optima or Deka deep-cycle?
    OK re. the 120A alternator - is that commonly available or what I have heard referred to as an "ambulance alternator"?
  4. purenrg
    purenrg
    Expand Collapse
    Jan 27, 2009
    80
    2
    My instructions sheet that came with my m4v only states a voltage of at least 13.8 volts minim, it doesn't state a Maxim voltage. I have run mine with as much as 16-17 volts. By running at this level I only seen about a 50w increase, it's safer to run it at 14-15 volts on a regular bases.
  5. kd4e
    kd4e
    Expand Collapse
    Jun 24, 2008
    21
    13.8 minimum, hmmmm, I wonder if that is due to current-handling capacity? (Lower voltage = higher current.)
    I am wondering as the Motorola Spec Sheet shows 12.5V as the test voltage.
    Right now I am planning a US Battery US 12V XC 155aH (75A for 77min) with a 25A float charge.
    Perhaps I should add a big Farad cap to keep the voltage from sagging on peaks?
  6. bob85
    bob85
    Expand Collapse
    Supporting Member
    Mar 30, 2005
    2,784
    585
    i have an old m4v with 455's, they use a crude bias circuit which runs hard into class ab, not as crappy as the texas star biasing but its basic with no regulation,
    early versions do have thermal tracking, later ones dont even have the tracking to help keep idle current under control,
    mine pulled 9 amps of idle current and got hot with no rf through the amp,
    running a stock m4v at higher than stock supply volts is asking for cooked transistors.
  7. kd4e
    kd4e
    Expand Collapse
    Jun 24, 2008
    21
    Sounds like 13.8V is about right then.
    Have you made any mods to improve the bias circuit that you could share, please?
    Any other improvements?
    I presume that some of the combiner-splitter and transformers may need to be replaced in order to improve efficiency - yes?
    I am hoping for 40-10M, dreaming of 80-10, 160-10, or even 160-6M ... WDYT?
  8. bob85
    bob85
    Expand Collapse
    Supporting Member
    Mar 30, 2005
    2,784
    585
    i removed one of the parallel dropping resistors in the bias circuit to lower idle current to 1 amp, bit of a bodge but it still sounds decent on ssb and runs much cooler,
    no other modifications, it deadkeys around 620w fm with 10w drive on the bird or lp-100 meter using whatever voltage the stock 90amp alt can provide, thats more than enough for 8 mrf455's imho.
  9. kd4e
    kd4e
    Expand Collapse
    Jun 24, 2008
    21
    [FONT=Arial,Helvetica]I just read this description about the [/FONT][FONT=Arial,Helvetica] Metron MA-1000 amp:[/FONT]
    [FONT=Arial,Helvetica]"A high speed 75 Amp Magnetic Circuit Breaker protects against short circuits, overdrive, and mismatched antennas. A protective diode will not allow the amp to operate if the supply polarity is accidentally reversed. A 75 degree thermostat mounted on the heatsink will switch off the amp if the temperature becomes excessive."
    I have not yet received my M4V - are any of these features in the M4V?
    If not do you see a way that they may be added?
    [/FONT]
  10. bob85
    bob85
    Expand Collapse
    Supporting Member
    Mar 30, 2005
    2,784
    585
    the m4v has 3 reverse polarity diodes, no thermal switch and no vswr/overdrive protection,
    a thermal switch bolts to the heatsink and wires in series with the on/off switch, simple enough if you dont mind making a hole in the board,
    overdrive and vswr protection would be a squeeze but it could be added, theres not much room to fit a vswr bridge between the relay board and the output filter, you would also need a suitable circuit and know what you were doing with it.
  11. kd4e
    kd4e
    Expand Collapse
    Jun 24, 2008
    21
    [FONT=Arial,Helvetica]I am guessing that the "high speed 75 Amp Magnetic Circuit Breaker" is sensing current surges and is tripping - an alternative to a superior but more complex VSWR sensing circuit.
    WDYT?
    I will also need to do something about band-switch filters.
    [/FONT]
  12. brian harrigan
    brian harrigan
    Expand Collapse
    Supporting Member
    Aug 4, 2017
    2
    I would like to get a schematic for the m4v with the mrf 455,s. Does anyone have advice on where to find that.
  13. nomadradio
    nomadradio
    Expand Collapse
    Analog Retentive
    Apr 3, 2005
    1,183
    664
    tecnicoloco likes this.
  14. bob85
    bob85
    Expand Collapse
    Supporting Member
    Mar 30, 2005
    2,784
    585
    Not sure if anybody mentioned it before but the m4v schematic is not drawn correctly,
    vcc & bias supplies are shown connected to the wrong side of the transformers & shorted to ground,
    i have not looked for other issues.
  15. brian harrigan
    brian harrigan
    Expand Collapse
    Supporting Member
    Aug 4, 2017
    2
    The messenger in the schematic is not the same amp by a long shot . Thanks just the same .I already have that one. Too many components are different.
Share This Page
