Thanks for your help with this one. I have a Turner Plus Three microphone with 3 conductors (red, black, white, plus the shield) that I'd like to connect to a Uniden Washington (5-pin ). The original materials for the Turner say black and red are for control switching, white is the signal (hot) lead, and shield is ground. I'm not sure how to match this up with the Washington 5-pin.
One site says the Washington is set up this way, but I'm not sure:
Pin 1 Audio
Pin 2 Shield
Pin 3 Receive
Pin 4 Sw. Wire (Swiching wire?)
Pin 5 Transmit
Has anyone connected these two pieces of equipment before? I believe the transceiver is electronic swiching, not relay switching.
Thanks!!
Pin 1 Audio
Pin 2 Shield
Pin 3 Receive
Pin 5 Transmit
Thanks!!
