MURS HT antenna
Jul 26, 2013
76
7
18
ALright, i have been looking around and all of the Diamond antennas and such from what i have seen have unusable SWR's on the MURS freq's. I have a baofeng uv-5r and would like to upgrade the antenna. I would like to use it to comonucite from an ultralight, to the ground. To me either by buying another handheld and putting up a Jpole for the house, setting up a mobile antenna on my jeep, and being able to use just the HT.
I really only want the need to buy another HT since i aleady have one, that way i can keep one on the plane, and one for handheld,car,house use and all i would have to do is swap antennas.
So is there anyone that makes a better antenna that will be compatable with my baofeng on the murs?
Or do you think i would be better off going with the GMRS route, and finding a better antenna for the HT's on that band?
You can also get one of the dual band extended gain antennas that is a long stiff-flexible wire radiator types and cut it down .... but will need an Antenna Analyzer to check your trimming work. I'd snip only 1/8 to no more than 1/4" at a time.
I plan on doing this with one I have to make good resonance on one of these type antennas to make usable on a 154mhz business freq. my workplace uses.
Good luck
    63Sprint has left the room.
