My Lightning 6 Quad antenna
Discussion in 'Amateur Radio Antennas' started by Drifter, Sep 23, 2009.
  1. Drifter
    Drifter
    Expand Collapse
    Aug 2, 2005
    359
    11
    It is up about 60' ft on my crank up tower.(y) I love this beam. There is also a 2meter antenna below the beam. They work great!
    [​IMG]
    [​IMG]
    [​IMG]
    #1 Drifter, Sep 23, 2009
  2. Quiksilver
    Quiksilver
    Expand Collapse
    Oct 23, 2006
    385
    17
    Sweeeeet!
  3. KingCobra_CDX882
    KingCobra_CDX882
    Expand Collapse
    Mar 30, 2005
    2,036
    45
    Bet your neighbors like you...LOL
  4. Marconi
    Marconi
    Expand Collapse
    Usually if I can hear em' I can talk to em'.
    Oct 23, 2005
    5,567
    607
    Great setup Drifter and looks even better. Can you confirm for me about the positions of the ver/hor feed points? The typical quad has the vertical fed at the 3:00 or 9:00 and the horizontal usually at the 6 o'clock position, but I think it is the opposite with the L6. I have an idea why that is, but I would like your opinion and if you found that confusing at first look? I have never owned a Signal Engineering quad, but would love to play a tune on that one.
    How say you?
    Give us some words about your success at tuning this monster and how she performs even considering conditions may not be the best right now.
    Thanks for your input.
    Marconi
  5. unit_399
    unit_399
    Expand Collapse
    EL CAPO
    Jun 17, 2008
    1,332
    555
    Drifter -
    Your pictures promote maximum jealousy !!!
    - unit 399
  6. HiDef
    HiDef
    Expand Collapse
    Aug 16, 2008
    543
    5
    Nice tower and antenna. Looks like an old Tristao or an earlier U.S. Tower.
    When you put that quad exactly 90 degrees away from a signal is the rejection really good?
    Next project could be to put a bunch of 2 meter quad elements on the same boom:D
  7. W5LZ
    W5LZ
    Expand Collapse
    Crotchety Old Bastard
    Apr 8, 2005
    6,832
    749
    And what has me puzzled, because I don't see what it's feeding, and you don't see it very often anyway, is what are you feeding with the ladder line?
  8. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Professional Amateur
    Staff Member
    Apr 6, 2005
    14,514
    5,864
    I'd say it's just the light and the imaging on the digital picture.Look at the element spreaders as well. They look the same,broken up.
  9. airplane1
    airplane1
    Expand Collapse
    Apr 15, 2005
    1,038
    13
    HI HI
    AP
  10. KJ4BAE
    KJ4BAE
    Expand Collapse
    Aug 14, 2008
    50
    I just put up a super hawk, the 2 element signal engineering antenna and you are right the feeding is opposite of what it should be. I put this thing together and i still cant figure out why it is like this. It is really confusing but the antenna works very well.
  11. Drifter
    Drifter
    Expand Collapse
    Aug 2, 2005
    359
    11
    Hello, Mine has it's horizontal at 3 o clock and vertical at 6 o clock.... She has been up three years now first as the Lightning 4+. which worked great as a 4 but I wanted more so I bought the upgrade kit which stretched the boom and added two more directors. As a 4 element she was fairly easy to tune.. When I upgraded I had some interference issues from my kids swing set and fort and fence and my neighbor's car parked on the other side of the fence. When I fold the tower over the antenna gets very close to those items. A lot of trial and error and cranking up and down till I got the numbers I wanted on the MFJ. I am scared to make any changes :mellow: but I have to install upgraded coax and the upgraded feed system from Signal Engineering to accomodate more output. (y)
    The Quad is currently being fed with LMR 400uf soon to be upgraded to LMR 600UF coax. The 2meter has 213 coax feeding it.
  12. Drifter
    Drifter
    Expand Collapse
    Aug 2, 2005
    359
    11
    Yes HiDef You have a sharp eye and very knowledgeable. The tower is a Tristao.. and yes the antenna is very directional and the rejection is awesome.
  13. Drifter
    Drifter
    Expand Collapse
    Aug 2, 2005
    359
    11
    Don't mean to do that. lol I just want to share. I like to look at great radio setups too.
  14. wambulance
    wambulance
    Expand Collapse
    Sep 23, 2009
    44
    Wow! That is sexy!
  15. Marconi
    Marconi
    Expand Collapse
    Oct 23, 2005
    5,567
    607
    Thanks KJ4BAE, IMO the difference is due to the SE being a voltage fed antenna where the wire is continuous while the traditional quads are current fed and have the resonant wire joined together at an insulator. Your SuperHawk tuner is a bit different in design compared to Drifter’s L4+ or L6, because your SH’s boom is not long enough to appear as a resonant ground element for the feeder to work against, so SE adds this floating ground side wire parallel to the open ended feeder. IMO, this is a very efficient feeder that transitions the impedance very smoothly from the coax end directly into the radiator---transforming the high impedance radiator to that of the feed line, while this is basically end feeding a resonant ½ wave element. The other half of the quad also contributes to the radiation of any quad design, but that is difficult for me to describe.
    Thanks for the confirmation Drifter. I believe you when you describe the interference issues you noticed in your yard. I tried to install my Long John 5 element at my location and I was never able to get a reasonable tune even tuning about 25’ high on a 18’ roof deck on my home. The antenna was overly sensitive to everything within 40’ - 50’ feet. Maybe if I could have raised it up to 40’ feet or more it would have worked fine. I ended up putting my 4 element back up and did not have the problem.
    Can you describe for us what the new power upgrade is? This must be something new from SE.
Share This Page
