Need a 6db Base Antenna For 406-512Mhz.
Discussion in 'Amateur Radio Antennas' started by Kirk2010, Aug 6, 2010.
  1. Kirk2010
    Kirk2010
    Expand Collapse
    Aug 6, 2010
    I have an ICOM F4001 400-470MHz. Am a member of CERT and building a base station at my home and need an antenna. Other members of group have been using a great antenna from Antenna Warehouse (here is the URL to the antenna I want: AWH-450 UHF base antenna
    BUT...antenna warehouse has stopped taking orders for this antenna stating that they can no longer get it!!!!
    Unfortunately, I don't know who the mfg is so I can't even research it to find one.
    Have attached a picture of the antenna here:
    [​IMG]
    BTW, the phone number in the photo is wrong, he has an error on his site.
    Can anyone help me identify this antenna? I really need one quickly. Anyone know of an antenna source who could help?
    Thanks very much for your assistance.
  2. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,377
    2,133
    Diamond X50A Antenna
    7.2db @ 70cm.
    Same one I use . . .
    The X50NA and X50A are excellent choices where ruggedness is required in a medium-gain, dual-band application.
    Special Features:
    • Fiberglass radome
    • Stainless steel hardware
    • Wide band performance
    • Factory adjusted – no tuning required
    • High wind rating
    • DC grounded
    Specifications:
    Band: 2m/70cm
    Gain (dB): 4.5/7.2
    Max Power Rating: 200
    Wind Rating: 135 MPH (no ice)
    Height (feet): 5.6
    Connector: UHF
    Element Phasing: 3-1/4l, 3-5/8l
    Remarks: Also available with Type-N connection.
      File size:
      4.6 KB
      218
  3. dudmuck
    dudmuck
    Expand Collapse
    May 21, 2007
    483
    4
    That AWH-450 has the feature of being adjustable.
    It would have the advantage of being able to be set to run on a wide range of frequencies, but the instantaneous bandwidth is 20MHz. So if you dont adjust it right, it wont work well.
    A ham antenna for 70cm band would be a good choice if you are on or near ham band. But i think your need might be on GMRS. If so, you would be better off googling around for GMRS antenna and pick one you like. Because good 70cm antennas dont have enough bandwidth for GMRS.
  4. Wire Weasel
    Wire Weasel
    Expand Collapse
    Senior Moment
    Dec 13, 2008
    2,618
    162
    Look up Hustler's line of commercial antennas. Just because your radio transmits over that wide of range doesn't mean you are going to be needing to transmit across that entire range. Where exactly are you TX'ing?
    Here's their Land Base HD line. How about 9db gain for ya - Hustler's parent company is called New-Tronics now.
    http://www.new-tronics.com/main/html/base_hd_406-512_9_db_gain.html
    #4 Wire Weasel, Aug 7, 2010
  5. W5LZ
    W5LZ
    Expand Collapse
    Crotchety Old Bastard
    Apr 8, 2005
    6,832
    748
    I think if you look at a few catalogs you will find several antennas the equivalent of the one you can't find anymore, that particular style/type isn't all that unusual. I think I'd make a few comparisons of specs, then pick the one you think would work for you (both performance and cost wise).
: antenna, icom
Share This Page
Members Online Now
  1. Robb,
  2. Peicsinc,
  3. hillbilly101,
  4. worldwidejack,
  5. dave457,
  6. kopcicle,
  7. Onelasttime,
  8. CrazyFin,
  9. sonoma,
  10. Ariel
Total: 273 (members: 11, guests: 188, robots: 74)
