NEED HELP WITH OLDER LAFAYETTE 625
cottentop
Nov 21, 2008
67
2
16
the panhandel of WV
Hi i have an older lafayette 625 from around 1970 0r even 1974 i need the
power and modulation pot's it is old and it is do for a tune up but my tech closed shop cb is not real hot here i know you cant git swing from these but i would like to tune it a bit
ps befor you all git mad my cb tech did show me how to use a sams and a diddle stick LOL :D thanks in advance
Model 625:
RF POWER adjust A17 thru A27 for max output..
MODULATION adjust R7 or remove diode X11 to defeat limiter
Model 625A:
RF POWER L6 thru L11, VC1, L12, L13 adjust for max output.
MODULATION VR4 or remove D10 for limiter defeat.
- 399
If you run into problems, Both Sparky's CB Shack and DTB radio have worked on my Lafayette 640 from 1976. I have been keeping it going. Al at Sprky's was to first tech not to laugh at me on the telephone for asking about geeting such an old radio tuned. DTB had repaired the modulation circut for me recently- It started going off fequency. I was pleased with the results from both.
Secret Squirrel
HI secret squirrl
well dont feel bad i have i of each of my first radios i also have a hb23a put it on the pdc 600 tonight and some one has ben in it as it is at 5 Watts swing to 7 and modulation is at 90% and claer just has a loos wire in the mike plug i will use it as a spair for the atv i have a johnson 123 mounted to a 2004 400 cc atv so momma can call me for a hot meal or coffee while i plow snow funny i used a 3 ft fg antenna and only 7 feet of 8x and gat an swr of 1.5.1 loud and clear 73"s your way :)
    63Sprint has left the room.
