Need some expertize opinion
Discussion in 'Amplifiers' started by Limeybastard, Aug 9, 2017.
  1. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    105
    Can someone take a look at this amp for me and tell me what they think, I see a lot of cuts and joins in the psu cables, is this normal? I contacted the seller he seems OK. It looks well used, he claims hes had it for a while and just changed brige rectifiers or something a few times on it.
    http://www.ebay.com/itm/Fatboy-Amplifier-/222601096205?hash=item33d40f2c0d:g:89sAAOSwvv9ZgklJ
  2. nomadradio
    nomadradio
    Expand Collapse
    Analog Retentive
    Apr 3, 2005
    1,133
    618
    No good for sideband. Built as AM-only.
    Never mind the switch marked "SSB". That's an outright fraud.
    rabbiporkchop, bob85 and Limeybastard like this.
  3. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    105
    How can you tell? cheers
  4. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,343
    2,107
    Just a FYI limeybastard; biasing is one electronic concept that pays to understand if you are considering amps. Like kicking the tires on cars - sorta.
    In a nutshell, biasing is the voltage feed control over the output power 'pills'. They need to get it at a specific rate - or curve - to give the pills a better distribution of power output tracking the output of the radio.
    FM radio output requires a 'C' type of biasing - which is what most AM operators use when they should be using 'B' type amp biasing. AM only radios should be used with B biased amps; however they don't know the difference - it seems. SSB requires 'AB' type of biased amps.
    If you have a radio that has SSB mode; then AB biasing is required to track its output in a linear fashion. If you use an AM only radio; then a B biased amp is best. Most of the CB amps on the market are 'C' biased; and not best for SSB-type radios with AB outputs. The Fatboy is C; Texas Stars are AB, while XForce are B class.
    #4 Robb, Aug 9, 2017
    rabbiporkchop likes this.
  5. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    105
    Yeah, I think Im done looking for amps , think Ill just pull the cord and get a run of a mill TX DX500 or 1600, probably DX500 and run it about 200W tops pep. Common sense says that getting the 1600 texas star is is going to introduce another whole ball game to the situation, better coax, better antenna situation, better PSU.. More add ons needed.
  6. Tallman
    Tallman
    Expand Collapse
    W9WDX Amateur Radio Member, KW4YJ EXTRA class
    May 1, 2013
    1,974
    957
    Power supply issues easily fixed. Buy one or two of these 50 amp units.
    [​IMG]
  7. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    105
    Job done, I bought a brand new 500v from ebay. You know, the seller that sells it then tells you to fuck off should a problem occur on first usage ;-)
  8. StrangeBrew
    StrangeBrew
    Expand Collapse
    Aug 15, 2011
    495
    363
    Not sure what the one in the OP is but Fatboy has made AB amps in the past.
  9. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,343
    2,107
    Not very familar with FB's either; but they are known for competition style C class amp. If they do AB biasing; then it is a further customization - IIRC. I'd be more impressed with them if they did it B class for AM only radios and not prep them for +20v operation . . .
  10. Klondike Mike
    Klondike Mike
    Expand Collapse
    May 31, 2010
    571
    186
  11. StrangeBrew
    StrangeBrew
    Expand Collapse
    Aug 15, 2011
    495
    363
    I have no use for a class C box myself, but we're not who he's building these for. His primary market is competition amps for keydown use.
    At least he does have better biasing available as an option, that's more than most of these guys do.
  12. w9cll
    w9cll
    Expand Collapse
    Jan 19, 2013
    2,885
    1,503
    100w and a decent antenna is all you need.
    Riverman71 likes this.
  13. Tallman
    Tallman
    Expand Collapse
    May 1, 2013
    1,974
    957
    Who told you that?
  14. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    105
    Indeed, hence the 500V, 100W?
  15. 543_Dallas
    543_Dallas
    Expand Collapse
    Jul 25, 2011
    1,235
    1,198
    100 watts AM? As in carrier? The Tejas Star 500 will fit the bill nicely. ;)
Share This Page
Members Online Now
  1. dinamo54,
  2. thumper937,
  3. Big_Harry304,
  4. CrazyFin,
  5. 309hellinois,
  6. FlatTOP,
  7. Dorian,
  8. dave457,
  9. Radioman1
Total: 320 (members: 11, guests: 216, robots: 93)
