new Sirio Tornado review / update
Discussion in 'CB Antennas' started by camaro1, Jul 16, 2013.
  1. dave457
    dave457
    Expand Collapse
    Jan 3, 2009
    452
    291
    There nice light antennas but very narrow banded
  2. Andrew McFadzean
    Andrew McFadzean
    Expand Collapse
    New Member
    Mar 15, 2017
    6
    2
    Hi - How do you decide what length to adjust the ground planes please? Is there a calculation?
  3. 222DBFL
    222DBFL
    Expand Collapse
    Jul 28, 2013
    3,301
    1,285
    The ground plane radials are pre drilled on that antenna if memory serves me correctly. Just pull the inside length out and when it gets tight, or where it's supposed to be, you'll know. Then spin it to find the holes for the outer length of the radials and use the self tapping screws to put them together. Pretty sure that is how they go together. They are pre drilled on both outer and inner part of aluminum. The total length should be around 6ft. They aren't full 1/4 wave ones.
    They are an Easy antenna to tune. Just takes some fine tuning to get it right. Start with the 1120mm measurement in the book and raise or lower tip for best match at desired frequency.
    That and get it off the ground at least 30ft. or more and away from obstructions. JMHO's.
    Also remeber that this is a very lightweight antenna and you will need to have a good plan in place for putting it up. Add a good 1:1 isolating balun and use good coax. Also a Low Pass Filter at the radio is a good idea. Again, just my experience with the Sirio Tornado. Good luck and be safe placing it up.
  4. Andrew McFadzean
    Andrew McFadzean
    Expand Collapse
    New Member
    Mar 15, 2017
    6
    2
    Thank you for the great advice - Im not familiar with a "Balun"!? and yes its going on a new 7m ali pole in my garden which takes it above the eaves - Great to know there is no adjustment needed on the radials. Its a brand new set up I have at my desk as I work from home on Trucks and Logistics just off A66 in Cumbria so want to keep in touch with truckers over as wide an area as possible, I did try some DX and CB in my younger days so its more of a play project that has already got out of hand and 5 times over budget!!! Hope the wife doesnt find out!! I just wend for RG58 coax as its only 5m required from my office window to Antenna - Look forward to posting some pics once it is up at weekend weather permitting. A
  5. Needle Bender
    Needle Bender
    Expand Collapse
    ...he thinks it's funny that I stepped in it
    May 15, 2010
    1,401
    288
    Nope, not me. I'll never again use a non-DC Grounded antenna. I mean
    WHY SHOULD I
    when there's so many on the market which are DC shunted, and in being so, provide a pathway to ground for excessive atmospheric voltage build-up?
    If a lightning strike hits only nearby - but close enough to heavily charge the local atmosphere, the residual post-strike voltage can be enough to damage a radio!
    - The 1st IF & AGC are taking the brunt of the energy, how can this be good for a receiver designed to be so sensitive as to hear down to a 1/4 of a microvolt?
    When there's a well-designed, well-constructed, DC shunted, full 1/4 wave radial, proven performance full 5/8 available, (namely the Penetrator SPT-500) WHY would anyone intentionally choose inferior performance?
    - To $ave the equivalent of a half gallon of gas a week for a year, then have to live with the inferior construction, performance and shame of having done so for years to come, IF the whatever non-Penetrator hoozy-whachit antenna even survives that long?
    We've often heard it said, "You get what you pay for",
    but I've also heard it said,
    "You deserve what you choose".
    It's so awesome the Penetrator legacy has been resurrected and the SPT-500 makes it once again available. (...but for how long??? :unsure: )
    - How sad that people cheap-skate out for relative junk just to save the cost of a milkshake a month for a year (n)
  6. camaro1
    camaro1
    Expand Collapse
    Nov 2, 2012
    988
    341
    yup my sirio tornado is packed away in the shed, it took out one radio ,,, during a snow storm the static build up from the snow/wind was enough for me to sit and watch the pl259 on the end on my coax arc and spark like crazy
    you can add a shorted tuning stub to bleed of the charge, but I just took it down, other wise it did work very well
    Needle Bender likes this.
  7. Needle Bender
    Needle Bender
    Expand Collapse
    May 15, 2010
    1,401
    288
    What are you replacing it with?
  8. camaro1
    camaro1
    Expand Collapse
    Nov 2, 2012
    988
    341
    its been down for a while now, that was before I got my ham lic. now I have 2m,6m and a A99 on the tower at about 50' and multiple wire antenna's and my sirio Gainmaster is still up in a tree about 40' to the base of antenna(going on 5yrs or so) so those are what I use now on 11m when im on
  9. Andrew McFadzean
    Andrew McFadzean
    Expand Collapse
    New Member
    Mar 15, 2017
    6
    2
    Got it assembled today and spent some time taping up every joint and screw/nut with the special black tape - Looked amazing but used some T-cut to get it extra shiney and set it up on patio -
    SWR straight away...
    Cept FM
    C1 1:1.7
    C20 1:1.4
    C40 1:1.2
    UK FM
    C1 1:1.15
    C20 1:1.0 - Perfect
    C40 1:1.4
    I could not be happier - Tomorrow it goes up on 7m ali pole so all going well will post pics soon
    Thank you for your support
  10. undertaker
    undertaker
    Expand Collapse
    Undertaker
    Apr 5, 2006
    1,542
    379
    I love my sirio tornado I live in west texas where the winds blows all the time. No problems at all..
  11. Andrew McFadzean
    Andrew McFadzean
    Expand Collapse
    New Member
    Mar 15, 2017
    6
    2
    Cant tell you how pleased I am with this antenna - perfect SWR 1:1 from installation - View looking East Across Cumbria on A66 - Its already been windy here today and although antenna sways nice in the wind the pole only moves slightly just outside my office window.
  12. dave457
    dave457
    Expand Collapse
    Jan 3, 2009
    452
    291
    What kind of coax you got there? Rg58, looks pretty thin
  13. Andrew McFadzean
    Andrew McFadzean
    Expand Collapse
    New Member
    Mar 15, 2017
    6
    2
    RG58 Military with sealed plugs - Its only 5m to rig so i guessed it would be fine - Only running standard 4w at moment
  14. Andrew McFadzean
    Andrew McFadzean
    Expand Collapse
    New Member
    Mar 15, 2017
    6
    2
    Sirio New Tornado 27 stood up to a battering in strong wind yesterday here in Cumbria
  15. 543_Dallas
    543_Dallas
    Expand Collapse
    Jul 25, 2011
    1,239
    1,209
    A friend of mine has an old penetrator that has survived a tornado, been blown over twice, had the coax connector burned out with too much power, we dropped it on his van before it was blown over the second time.
    He has a beam now and gave it to another guy that is just getting started. Even without the accidents just being put up in Texas for over 20 years says a lot for it.
    222DBFL likes this.
Share This Page
