New Super Penetrator 500
Discussion in 'CB Antennas' started by basstracker1970, Jul 28, 2013.
  1. basstracker1970
    basstracker1970
    Expand Collapse
    Nov 6, 2012
    156
    23
    I just ordered the new spt-500 and was looking over the instructions and noticed that they say to make it 19' long. I thought I read somewhere for 11 meter 22' was where you needed it. can someone come in here and clear this up for me I want to get it together the right way. It also says to make the ground plane radials 105" long. Is that correct for 11 meter use? Thanks for any help here.....
  2. radioman24
    radioman24
    Expand Collapse
    Jul 19, 2009
    339
    13
    may I ask where you ordered it from?
  3. basstracker1970
    basstracker1970
    Expand Collapse
    Nov 6, 2012
    156
    23
  4. The DB
    The DB
    Expand Collapse
    Aug 14, 2011
    1,602
    692
    The 19 foot length is just a starting point, if you follow the directions you will lengthen or shorten the overall length when you tune the antenna using standard SWR tuning methods. The overall length of the antenna is dependent on several things, not the least of which is the matching network. In this case as said matching network is not adjustable in and of itself it determines the overall length of the antenna for any given frequency.
    When it comes to the radials, this isn't a resonant antenna such as a quarter wavelength antenna, so resonant lengths on the radials don't matter quite as much. As long as they are close, the antennas matching network will tune the overall antenna as a whole, and this includes the radials. That being said, they are already close if not a resonant length.
    I'm curious, do they still advertise these as "not for 11 meter use"? :LOL:
    The DB
  5. hotrod
    hotrod
    Expand Collapse
    Feb 16, 2007
    2,326
    171
    on the radials yes 105 is correct. correct lenth is around 22-22 1/2 feet in lenth from end 2 end. 23 feet is the max for that antenna. be SURE to use exact overlapping of each verticle
    section this is cruital for correct tuning
  6. basstracker1970
    basstracker1970
    Expand Collapse
    Nov 6, 2012
    156
    23
    I think the instructions says 3 inches lap and adjust the last one to proper length.
    1 person likes this.
  7. Road Squawker
    Road Squawker
    Expand Collapse
    Jan 19, 2011
    1,317
    640
    that is correct, I just assembled one last week.
    the instructions actually state 19 feet and 22 feet overall on the same instruction sheet:blink:, (HYGAIN is covering their azzes about metal antennas and CB users). the old P-500 were about 22' 9"
    start with 22 . if it resonates too low, then it is too long, and vice versa. but, 22 feet will get you in the ballpark.
    I used 22 feet and it was resonant @ 27.205MHz with the feedpoint @ 35 ft.
    then I shortened it by 12 inches and it resonated @ 28.425, right where I wanted it to operate.
    yes, the 105 inches is correct for the radials @ 27 MHz,... and don't forget to use NOLOX when you put it togeather
    2 people like this.
  8. Marconi
    Marconi
    Expand Collapse
    Usually if I can hear em' I can talk to em'.
    Oct 23, 2005
    5,463
    587
    DB, I have and older new manual that has the 19' feet in it, but I can't find my copy of a New SPT 500 manual. A friend sent me a copy of an updated manual, where DXengineering changed the 19' shown in the manual to 22' feet, just like Hotrod suggested earlier in this thread.
    I figure 19', even as a starting point would likely be way too short for 10 meters...even if DXE intended to advertise it as a 10 meter antenna in their public notices. I don't think that beta matcher used is very broad banded either, but I'm not sure how far it will really go in tuning. I think somebody at DXE just made a mistake. I hope I can find that new manual around here somewhere, and if I do I'll post it to a new thread.
    I think I've already posted this manual on WWDX, but as I recall it was probably buried in some thread that does not relate to the SPT 500 specifically. I did a search, and I got a few hits, but I didn't read them all...just too much reading.
    #8 Marconi, Jul 29, 2013
  9. Road Squawker
    Road Squawker
    Expand Collapse
    Jan 19, 2011
    1,317
    640
    HUH????? Dx Engineering didn't change anything:confused:
    HY-GAIN (a.k.a. MFJ) states both dimensions, just like I said earlier.
    http://www.hy-gain.com/pdffiles/SPT-500.pdf
    HY-GAIN calls it a 10/12 meter antenna
  10. Marconi
    Marconi
    Expand Collapse
    Oct 23, 2005
    5,463
    587
    Well Road Squawker, you did see the New SPT500 with a manual the shows 19' overall length. I have the same manual. I may have misunderstood what Eastside described in his manual, because he could have easily seen the 22' feet number in the Specs Area of the manual and there still be 19' feet noted in the image of the antenna. So you might be right there has been no change, but I still think somebody made and error noting the overall was only 19' tall.
    Here is a link to the thread on WWDX: http://www.worldwidedx.com/cb-antennas/108500-bbt-delivered-hy-gain-penetrator-500-today-23.html
    Here are some items I copied from the thread above that gets to the real issue...so you guys don't have to read it all unless you wish.
    See the * I added to the top of this page in the manual where it plainly notes the antenna height is 22' feet. The 19' foot error is on the page 4, which shows the overall length is only 19' feet, just like Eastside has suggested.
    View attachment Two pages from my SPT500 manual.pdf
    #10 Marconi, Jul 29, 2013
  11. Road Squawker
    Road Squawker
    Expand Collapse
    Jan 19, 2011
    1,317
    640
    YOU DON'T READ VERY WELL, DO YOU?
    you REPEAT what I just said ,.... and act like you invented it.
    HY-GAIN is owned by MFJ, NOT DX Eng
  12. Marconi
    Marconi
    Expand Collapse
    Oct 23, 2005
    5,463
    587
    Yep Road Squawker, at 75 years I don't see too well either.
    All I know about the SPT500 is that DXE was promoting the antenna, and I think they were the first ones selling it too. I was just acknowledging the fact that you were right earlier, I didn't mean to piss you off that bad. Take a break and cool off a bit, this discussion is not that important to get all excited about.
    I don't mind finding out that I was wrong about something, the truth is more important to me than a silly argument in vain.
    Sorry I got you so upset and caused you to start yelling at your computer monitor.
  13. hotrod
    hotrod
    Expand Collapse
    Feb 16, 2007
    2,326
    171
    he is correct. thats why it has 19 feet .then later has 22 feet. i suspect the 19 feet is a 10
    meters setting but im not sure.start with 22 feet you should be close. if ya start at 19 feet
    its gonna be way too short
  14. Road Squawker
    Road Squawker
    Expand Collapse
    Jan 19, 2011
    1,317
    640
    nice try Gomer,... I,m not pissed at all, but, YOU do this ALL the time, you are a "namedropper" on this and other forums.
    the SPT 500 was released @ Dayton a couple years ago,... by HY-GAIN, not DX ENG
    ... and the 19 feet figure is NOT a mistake, MFJ markets it as a 10/12 meter antenna.
    go figure what a 1/2 wl on 12 meters is..................and don't take out your anger on your calculator.
  15. radiodawg259
    radiodawg259
    Expand Collapse
    Oct 27, 2008
    51
    2
    SP 500
    You can go to CB Tricks and get what you need for the antenna set up for cb use..
Share This Page
