Not Sure What to Do Buy a AT6666 or buy i heater.
Discussion in 'CB and Export Equipment and Accessories' started by CrazyD, Jan 3, 2018.
  1. CrazyD
    CrazyD
    Expand Collapse
    Sep 25, 2012
    32
    4
    well i was thinking of getting a anytone 6666 because it has about 60+ watts out on SSB but i already have a AT5555 so here it is should i buy a 200 watt heater for the at5555 or buy a AT6666 the AT5555 is a V6 so its current but low power out.
  2. 9C1Driver
    9C1Driver
    Expand Collapse
    Aug 13, 2008
    2,924
    694
    If you want to make an improvement people will notice go with a small amplifier. Changing from a 30 watt radio to a 60 watt radio will give you 1/2 an S unit. A nice 200-250 watt amplifier would be nice for you.
    CrazyD likes this.
  3. W2EKG
    W2EKG
    Expand Collapse
    201 Mike Action
    Dec 30, 2015
    210
    111
    Get this "heater," comes with extra 10 Ohm Resistors. You'll be blowing smoke on da band!
    #3 W2EKG, Jan 4, 2018
    CrazyD, 309hellinois and Tallman like this.
  4. Tallman
    Tallman
    Expand Collapse
    W9WDX Amateur Radio Member, KW4YJ EXTRA class
    May 1, 2013
    2,072
    1,032
    Safe Sex optional.
    CrazyD and W2EKG like this.
  5. Big Kahuna
    Big Kahuna
    Expand Collapse
    Jul 31, 2008
    180
    109
    KL203 will get you 100+ SSB for under $70. A lot cheaper and more power than buying a radio that isn't much different than the one you already have. Heater all the way.
    CrazyD and K3ACZ like this.
  6. Tallman
    Tallman
    Expand Collapse
    May 1, 2013
    2,072
    1,032
    Just be sure that you do not dead key more than 2 watts into the KL-203 and don't swing more than 5 watts. KL-203 amps are cheap and as long as you don't overdrive it they work fine.
    K3ACZ likes this.
  7. CrazyD
    CrazyD
    Expand Collapse
    Sep 25, 2012
    32
    4
    thanks for the input guys i think i got my answer i got a 50 amp power supply will it run a 200-300 watt heater ?
  8. Tallman
    Tallman
    Expand Collapse
    May 1, 2013
    2,072
    1,032
    It should max out at 600 watts.
  9. CrazyD
    CrazyD
    Expand Collapse
    Sep 25, 2012
    32
    4
    sounds good to me i think i might get a 300 watt then half what the supply can produce and use my old 12amp power supply on the radio
  10. 9C1Driver
    9C1Driver
    Expand Collapse
    Aug 13, 2008
    2,924
    694
    On a base 250-350 watts is plenty. Beyond that if you want a big improvement work on your antenna system. I'd rather run a KL203 off an IMAX at say 80 feet then a 600 watt amp at 20 feet.
  11. W2EKG
    W2EKG
    Expand Collapse
    201 Mike Action
    Dec 30, 2015
    210
    111
    I love when Box Builders lock horns LOL!
    309hellinois likes this.
  12. CrazyD
    CrazyD
    Expand Collapse
    Sep 25, 2012
    32
    4
    i have some big trees but i use a A99 i would love to get a IMAX but not sure if its worth upgrading.
Share This Page
