Radio Parts
Discussion in 'Amateur Radio Gear Swapshop' started by Pamm r, May 22, 2017.
  1. Pamm r
    Pamm r
    Expand Collapse
    New Member
    Apr 4, 2017
    43
    7
    I need a meter for a 710e Uniden. Where can someone buy parts for radios????? Either new or used
    cbkidd1 likes this.
  2. jon666
    jon666
    Expand Collapse
    Jan 24, 2006
    1,018
    312
    best chance is ebay. i see them time to time.
  3. space cowboy
    space cowboy
    Expand Collapse
    Quack Quack
    Oct 16, 2012
    1,369
    431
    sometimes your only option is to buy another radio and pull it from that.
    I do like those radios. one of the best sounding out there.
  4. Pamm r
    Pamm r
    Expand Collapse
    New Member
    Apr 4, 2017
    43
    7
    Can I have made an ext S-Meter or an inline s-meter is there such a thing???
  5. space cowboy
    space cowboy
    Expand Collapse
    Quack Quack
    Oct 16, 2012
    1,369
    431
    I can plug an external meter into the PA port on my 2950dx so I know it can be done. you just need to find someone who is capable and willing.
  6. Pamm r
    Pamm r
    Expand Collapse
    New Member
    Apr 4, 2017
    43
    7
    I have never seen an ext meter. Maybe I can get one and wire it direct to where my meter is because even when my meter worked it was too small.
  7. space cowboy
    space cowboy
    Expand Collapse
    Quack Quack
    Oct 16, 2012
    1,369
    431
    analog meter to analog meter, it should be easy enough. I have no idea if you could go bigger without changing the readings or putting a strain on the circuitry. it is one of the bigger CB meters out there already.
    Pamm r likes this.
  8. scout943
    scout943
    Expand Collapse
    Apr 22, 2005
    349
    30
    Pamm r likes this.
  9. jon666
    jon666
    Expand Collapse
    Jan 24, 2006
    1,018
    312
    years ago a company ldg made a big s meter. in a cox it sat ontop of your cb. but i haven't seen one in years
    Pamm r likes this.
  10. Pamm r
    Pamm r
    Expand Collapse
    New Member
    Apr 4, 2017
    43
    7
    Wow that would be great
  11. Pamm r
    Pamm r
    Expand Collapse
    New Member
    Apr 4, 2017
    43
    7
    Thanks, I looked but none for Uniden
  12. LeapFrog
    LeapFrog
    Expand Collapse
    χρυσοποιία
    Feb 15, 2016
    1,350
    438
    As long as the full-scale rating is the same as your factory meter (100 mA and so on)
    You can use an external meter usually without problems, I have a Cobra 29 LTD with a much bigger Cobra 2000 *style box square meter resting on top of the radio, that radio stays on my bench and I liked the bigger (easier to read) meter so it sits like that.
    The two wires are ran thorough one of holes used to mount the mic hanger clip, it's not pretty (I didn't drill any holes though) but it works and is a lot easier to read.
    Another option would be to see if you can *delicately* remove the original meter and "get it unstuck" using vapor of denatured spirits, or a jewelers screwdriver and carefully loosening the two tiny screws under the tape (you cannot always access these screws on all meter types) just a tad, and lightly re-tightening them after the meter moves correctly again. The movement is extremely delicate, and is easy to destroy if you are not careful or with a steady hand.
    You might find that after the original one is removed (I don't know for sure)
    It may look like a Cobra 2000 meter, and perhaps you could get away with swapping the meter face "decal or placard" from the original one to the "modern" (readily available) meter.
    *If after all, the Uniden external dimensions DO match a new style meter; swapping the face may the way to go if the original movement cannot be saved.
    In this video Mike is using a solvent, for the inexperienced out there please be careful as some solvents will melt through certain plastics in no time, permanently disfiguring them.
    I hope that helps
    -Leap
    #12 LeapFrog, Jun 9, 2017
    Pamm r likes this.
  13. Pamm r
    Pamm r
    Expand Collapse
    New Member
    Apr 4, 2017
    43
    7
    Thanks, Do ypu think I could cut the plug off this meter and attach to my uniden pro 710e ?
    SainSmart External S Meter/SWR/Power Meter For Yaesu FT857/FT897
    #13 Pamm r, Jun 17, 2017
Share This Page
