Radios auto tuner keeps hunting and a fix
Discussion in 'General Ham Radio Discussion' started by Tallman, Jun 1, 2017.
  1. Tallman
    Tallman
    Expand Collapse
    W9WDX Amateur Radio Member, KW4YJ EXTRA class
    May 1, 2013
    2,089
    1,039
    Been a long while since I went mobile with my ham radios. I use the MFJ antennas that resemble the fire sticks. Even though they were tuned with my antenna analyzer, the radio tuner will still hunt the lowest SWR when keyed. I hooked up a radio I hadn't used for a while and the tuner kept hunting with out stopping.
    I hooked up the analyzer and the SWR was almost perfect. Now I was confused. (Not unusual anymore)
    Trying to remember if I had this problem on this radio before I checked my notes and had no troubles listed for this radio. I got my 50 ohm test load and tested it again and lo and behold the search was on. After about ten seconds it finally locked down. I tested on the other bands and the process repeated on all of them.
    I retested each band again and lock down was less than a 1/4 of a second for each one.
    Went out to the mobile and it worked perfectly. By tuning it back up on a resistive load it, I guess centered the tuner on the frequency on a resistive load. it must have been 7 or 8 months since the radio had been used as the base unit and not in the mobile. The base antenna check out okay just a little high on 20 meters.
    So if you have one that's hunting take it to a dummy load and see if that fixes it. It could save a repair cost you don't need.
    #1 Tallman, Jun 1, 2017
  2. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Professional Amateur
    Staff Member
    Apr 6, 2005
    14,441
    5,769
    That's strange. Tuning into a dummy load should have nothing to do with clearing any issue. Are you sure you didn't have a loose coax connection you overlooked and it was tightened when hooking the tuner back up to the antenna? A loose shield connection and stray RF can cause tuner hunting.
  3. Tallman
    Tallman
    Expand Collapse
    May 1, 2013
    2,089
    1,039
    Cables were the first thing I checked. The tuner is loaded with reactive components.
    The very function is to react with the antenna to get SWR minimized. Running it into a resistive load forces it to go back to center and nonreactive state. Sort of like a wheel alignment eliminates pulling to one side.
  4. fourstringburn
    fourstringburn
    Expand Collapse
    W9WDX Amateur Radio Club Member K5KNM
    Feb 11, 2007
    1,570
    940
    Break down and get a Little Tarheel screwdriver antenna and remote tune all bands (model dependent) with 1 antenna.
    RatsoW8 likes this.
  5. RatsoW8
    RatsoW8
    Expand Collapse
    Supporting Member, W9WDX ARC Member - WD8T
    Nov 3, 2009
    3,102
    1,341
    I agree with CK on rf getting into the tuner. I used to use an LDG tuner that would hunt for a tune when it didn't need to and just grind until I bypassed it. Just turn off the tuner and check the swr.
  6. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Staff Member
    Apr 6, 2005
    14,441
    5,769
    Yeah I know how the tuners operate. I have an automatic tuner (Yaesu FC-40) but have NEVER had an issue like that where I had to tune into a dummy load to "reset" the relays to prevent hunting. I have had it fail to tune and simply go into bypass mode but that was due to an extremely highly reactive antenna with a very low impedance. I would have thought your tuner should have been able to find a match after running thru all the combinations even if it took 10 seconds or so to do it.
  7. Tallman
    Tallman
    Expand Collapse
    May 1, 2013
    2,089
    1,039
    You guys are probably correct. I don't know if the issue was because of no activity for a long time, going from base to mobile for the first time. It could be I misinterpreted the results, or my cat had a hair ball, or feed back through the DC power, I wasn't holding my tongue right the Band-Aid on my finger fell off, Rod Serling was in the house...
  8. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Staff Member
    Apr 6, 2005
    14,441
    5,769
    He's a frequent visitor to my house as well as Mr. Murphy. :D
  9. Tallman
    Tallman
    Expand Collapse
    May 1, 2013
    2,089
    1,039
    They live here and I guess when things are working right they are out visiting other people. Although Mr. Murphy is behind on his rent......
    Captain Kilowatt likes this.
Share This Page
