Printed circuit boards used to be an expensive proposition to have custom-made. Automation and the internet have reduced the cost a lot the last 20 years, but the per-order setup fee is still a bit steep. There's a low-tech way to reduce the item price.
Combine multiple boards in one order, and shear them apart. This spreads the per-order setup fee across three or four products, instead of just one.
Here's one expample.
The big one is the latest low-voltage pcb for the Pride DX300. I use a large power resistor on this board, and finding a batch of 50 or 100 of these cheap is a hit-and-miss proposition. As a result, the board gets designed to match the mounting requirements of each batch of power resistors. Sounds a bit like letting the tail wag the dog, but first I buy the resistors and then the board gets configured to match them.
Buying 50-Watt resistors at the full catalog price is never my first choice. Especially when I buy 50 or 100 at a time.
The lower-left of the three small boards is an adapter. It will put a 4-pin mike socket in place of the 5-pin socket on your Cobra 142, 2000, Uniden Madison, Washington and similar 40-channel SSB radios made by Uniden. It keeps the two ground circuits separate and eliminates the 'squeal' issues you get doing this the simple way. It also allows the use of roger-beep/5-tone beep/Bump-Bump boards that don't have a relay to mute the speaker. This one is version 6, and has two relays. One to key the transmit side, and one to delay turning the speaker back on when you unkey. This eliminates the unkey "POP" you get from the speaker when using a single relay.
The other two are the full-swing carrier control for Browning and Tram tube-type radios.
Now the real work begins. Getting hundreds of boards built.
